Question about Symbol MC9090 Barcode Scanner
Symbol PDT 8100 and I2of5 barcode reading problems
Has anyone experienced problems reading I2of5 using the Symbol PDT 8100? Having done some reasonably extensive tests I have come to the conclusion that it will only read I2of5 barcodes of either 10 or 14 digits in length. This is true regardless of: 1) whether my own or Symbol's scan demo program is used (eliminating my software) 2) regardless of which of two PDT 8100s I use (hopefully eliminating any hardware problem) and 3) regardless of the source of the I2of5 barcodes (presumably eliminating any quality / out of tolerance probs with the codes.) Symbol are the leading portable barcode scanner company in the world - I just can't believe that one of their devices would have this problem inherent but that's what the results of my tests so far point to. Has anyone got a Symbol Pocket PC based device that they would do a very quick scan test for me if I emailed them some I2of5 barcodes? TIA Tony I am using a Motorola WT4090 barcode scanner. I cannot get the scanner to read an I2of5 barcode in the Wavelink program. In a wordpad on the device itself it will read and decode the barcode without issue. But when I try to scan in the Telnet session it will not scan the barcode. I have the min set to a 6 and max set to 10. I am using a 8 digit barcode. Please if you have any info or ideas email me at rclark@rtiww.com. Thank you!
  • heman_emis May 14, 2009
    Hi I have a Motorolla MC9090 scanner and i have the same problem. I even used the Wavelink Product Configuration Utility and it shows that the changes on the device are saved but yet in the Telnet session it fails to read the barcode. As per a suggestion here i left the minimum and maximum length to 0 but the problem is still there.....its really frustrating and i still have no solution. If anyone can help out with this problem it would be greatly appreciated.
  • 97 Answers
Normally I2of5 comes disabled as default in wavelink software.
You will need to enable it and if you are scanning barcodes of different legths, set both the maximum and minimum to 0 value. This will allow any length.
If you still have problems, get back in touch with me and send me a sample barcode as I have a verifier which will allow me to determine whether there may be a problem or not.
Posted on Mar 26, 2009
How to restart Symbol PDT 3100 ? Thanks !
  1. hi,
    please follow the given link ,you wil find the solution of your problem ,step by step.
    please also follow the instructions.
    http://www.ehow.com/how_7184696_reboot-pdt3100-symbol-barcode-scanner.html
    Good luck
Jan 12, 2011 | Symbol PDT 3100
I need help in configuration of Scanner from Symbol MC3090. I want to scan a I2of5 Barcode which is 20 digits long. But the scanner did not scan it. We have a mobile application that is used to scan...
The length of the barcode is usually setuped in the the scanning application to avoid an partial scan or missdecoding. Please checkthe scanning options and stup the egth to 20 characters
Aug 04, 2010 | Symbol MC3090
Dear all I need help in configuration of Scanner from Symbol MC3090. The scanner settings I could'nt change in the system or better: where can I change this settings? I want to scan a I2of5 Barcode which...
You would need to configure the application which are you using to scan, there is usually one default length for the barcode preselected.
If you are using ScanWedge, download the CtlPanel application, start it goto Scanner settings, decoders, I2OF5 and length. Dont forget to make the settings persistend
Jul 06, 2010 | Symbol MC3090
We have several Symbol PDT 3100's with our old computer companies software downloaded on them. How do we delete these programs and set up the PDTs to be able to read and download as "text" files which we...
hi does your PDT 3100 have the Oneil's RSwin software if it does i can trade your PDT's for new ones. is the one that says Login Electronic Picklist record center Ops etc. etc. rupertohdz@prodigy.net.mx
Jun 22, 2010 | Symbol PDT 3100
I have bought a second hand PDT3100 se823000. It has installed a program I do not need. I need to read bardodes with format 111111.11 That's all. How can I make this PDT reader just a reader of barcodes ?...
You have to unistall the program that is inside unit you purchased and load one you are using. I can help you during this configuration. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Oct 14, 2009 | Symbol PDT 3100
Software/ help with symbol pdt 3100
We have all sofware that you need, obviously I cannot post them here so please contact us. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Sep 18, 2009 | Symbol PDT 3100
Symbol PDT 6846 - Scanner won't read 13 digit barcodes (program returns "not on file"). How do we update the scanner application?
This sounds like a programming issue. What application are you using? If you are using a terminal emulation software then you will need to check your host for the issue. If you are using a batch program where the files are stored on the scanner then you will need to check your "validation" files to make sure the code you are scanning is in the scanner.
Jun 29, 2009 | Symbol PDT 6846 Portable Terminal
Printing AklphaNumberic Barcode using I2of5 Format
Indeed, I2of5 is numeric, use the 3of9 or 128 A or B to encode alphanumeric characters. Roberto Martinez Mexico bartech9@yahoo.com.mx
Nov 13, 2008 | Zebra Z4M Printer
Symbol MC9090 Barcode Scanner Logo
1,115 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
