-   i was getting e0 and e1 with f5 -- searched them, found these tips, played around with the latch and held cancel for a minute. looks like it worked. thanks!
-   Guest
Mar 19, 2009
-   Where's the cancel button on a Whirlpool Accubake Oven? -   Guest
F5 - E0
Door switches do not agree (condition exists when door switch is closed
indicating an open door, and latch switch is closed indicating a locked
door)
1. If door latched:
Disconnect power from unit.
Check wires and connectors from control to door switch, then from
door switch to control. If no damage to wires and all connectors okay,
proceed to step C.
Replace door switch.
Re-apply power.
Press and hold any key down for 1 minute to clear F5 failure code
from memory. F2 will appear. Press CANCEL and observe for 1 minute to
ensure operation is correct.
Comments:
Feb 10, 2009
- F5 - E1
Self clean latch will not lock 2. If door not latched:
Check wires and connectors from control to latch switch, then from
latch switch to control. If no damage to wires and all connectors okay,
proceed to step C.
Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage
terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light
contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control.
Press and hold any key for 1 minute to clear R failure code from memory.
F2 will appear. Press CANCEL and observe for 1 minute to ensure
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Feb 10, 2009
- I hope this works for this site. HERE is the whole magilla.Just in case that don't work copy and paste this: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes
Was this helpful?
Yes
No
Popular Solutions for Whirlpool RBS305PDS Electric
I hate my accubake oven. It has never held a oven temp for more then five minutes. Tech has been out...
(More)
I hate my accubake oven. It has never held a oven temp for more then five minutes. Tech has been out here once, calibrated thermostat 10 degrees, yet it took 1 hour to broil pork chops since temp was 200 degrees. I bake twice a week and have never had a item come out not burnt on the outside and dough in the middle. Do Not Buy this Stove, dealer is not receptive at all, poor service, I want a new stove now....this one was purchased Dec 2008!
start button on whirlpool electr built in oven won't work. Just beeps but does not turn oven on....
(More)
start button on whirlpool electr built in oven won't work. Just beeps but does not turn oven on. Model # RBS27PDB4 Cass
My whirlpool accubake built in oven RBS275PBD84 won't start. If you press start it beeps a few times...
(More)
My whirlpool accubake built in oven RBS275PBD84 won't start. If you press start it beeps a few times but nothing! One other button (minutes up) to set timer does not work. Any ideas?
My oven light doesnt turn off and when I try to turn to bake or clean it says door in red as though...
(More)
My oven light doesnt turn off and when I try to turn to bake or clean it says door in red as though it is not closed however it is closed and wont turn on.
The inner glass of my Whirlpool oven ( model RBS305PDS16) broke. I purchased the glass and removed...
(More)
The inner glass of my Whirlpool oven ( model RBS305PDS16) broke. I purchased the glass and removed the door. I have taken the door a part and would like instructions on the proper way to reinstall the glass. Can you help, please....
