Question about Gateway MT3705 Notebook
My fan sounds broken
It was running and then made a sound like rattling and then the fan quite and has not worked since, but it sounds like it's trying to so it might be jammed or off balance? I don't know how to take it apart anfter you get all the screws out to look at it.
    President:
  • 1,902 Answers
Flip the computer back over after all the bottom screws are out and remove the keyboard and the plate right above the keyboard. This will allow you access cause there are 4 more screws up top that need to be removed
Posted on Feb 09, 2009
Rattling loud fan dell optipilex 780
Anonymous,
You may want to replace the fan. You can call the Dell Spare Parts Department at 1-877-717-3355 to purchase a fan.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 20, 2014 | Dell OptiPlex 780 PC Desktop
My televiosion hs a rattling sound, it displays cooling fan 2 but the sound goes away after a short period of time. I have had a repairman out but the problem still isnt fixed after tow visits
Hi.
The rattling sound is usually coming from one of the internal fans. The fan may make noise because one of the blades is broken, because of dust or foreign objects in the fan or because of a defective fan bearing. If the noise goes out after a while then the problem is likely a defective fan bearing. If display is indicating that there is a problem with fan 2 then fan 2 must be replaced even if at the moment of testing is not making noise.
Regards.
Ginko
Sep 10, 2011 | Samsung Televison & Video
Fridgeair dishwasher not working making loud sound. water comes in and I can make it drain out but washer does not start
Hello
bearings in the heater fan may get worn out or rust. If this happens, it may become very noisy, either grinding on the bearings, or scraping against the rust. If this happens you need to replace the fan motor. Sometimes, a fan blade may come loose, and you need to replace it.
Sometimes it's the motor that makes the noise you hear. The motor has bearings in it which may become worn or get rusty. When the bearings get worn, they allow the shaft to wobble which can get quite loud. If there is a spin seal leak, water may get inside the motor, washing the bearing grease away. If the spin seal is leaking, you'll notice water leaking from under the dishwasher. There is also a disc attached to the top of the motor called a slinger. It sometimes breaks off and spins around the motor's shaft while it turns, causing some noises. You will need to replace the motor if the bearings are bad. You also need to replace the motor if the slinger is broken as well.
Newer dishwashers may make a squealing or rattling noise on the first run. This is because it has not had any water in it yet, and the motor seals are dry. You may hear this in a unit that hasn't been run in a week or more as well. You should operate the dishwasher regularly to keep the sump water from getting smelly, and to keep the seals lubricated. You can add a quart of water to the sump before running it.
Rattling noises may be produced by dishes rattling inside the dishwasher due to the water pressure from the sprayer arms on the dishes. To determine if the rattling is a loading issue, run the unit empty. If the sound is persistent, it may be that there is debris in the pump.
dishwasher water-inlet valves are noted to make a hum that lasts about 60-90 seconds several times during a washing cycle. This hum is a different hum than the sound of the motor running.
A rhythmic knocking or thumping sound may be caused the sprayer arms hitting something as they go around and around. Rearrange the dishes and resume the wash.
A clunking or clanking may be heard when the detergent cup opens; while a clicking sound may be produced by the timer or electronic control panel.
A solenoid makes a snap sound when it opens. This happens about six times during each load.
Pipes rattling or banging may be caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The sound is caused by the water slamming into the closed section of pipe. A plumber can install an anti-hammer device.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and then remove the item that is making the noise or replace the pump. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher.
Send this page to your printer
Aug 06, 2011 | Dishwashers
Loud rattles in front fan and loud hummiing from unit itself along w minimal cooling and freezing up
Unfortunately sounds like the squirrel cage in the front may have broken off at the hub. This is a pretty extensive job on most window units, not all that costly (parts wise) but quite a lot of labor.
Apr 19, 2011 | LG Goldstar GWHD5000 wall/window Air...
Got into the truck yesterday and it was making some noises LIKE a squeeling fan belt, but it wouldn't subside with time as squeely belt typically does. Got out, popped the hood (engine still...
Park your car overnight and put a large white piece of paper underneith your car. In the morning check the paper. If the paper is wet with liquid, you could have a water pump leak.
http://www.ehow.com/how_7679_tell-cars-water.html#ixzz180pVuDWY
Dec 13, 2010 | 2005 Toyota Tacoma
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Loud rattling sound from fan in frezzer, then quit running - doesn't work now. This is a compact two-door model (4.2) cf.Possible cause/problems? How do I diagnose? Where can we get parts?
Sounds like the bearings in the fan motor. Replace the evap fan motor. You should be able to look under refrigeration parts to find your local parts house. But thats what it sounds like to me.
Aug 10, 2009 | Frigidaire Refrigerators
Getting major rattle about every 3-5 minutes - very regularly. Sounds like piping shaking against back of fridge. Started about 3 AM and it is now 4 AM.
You may have afan motro going out out they do rattle and then quit and then do it again. Call service tech for free estimate on repair. When the fan motro goes out everything quits. Compressor overheats Everyhting melts. Rus
Jul 04, 2009 | Kenmore Refrigerators
When I start my MPV, there is a rattling sound from behind the glove compartment box. I removed the box and there is a unit that seems to have a motor of some sort inside. WHat is that for. If I disconnect...
this is the interior fan motor and housing.The rattle may be a piece of debris in there(i.e. leaf or a piece of paper)or a thing in the electric motor called a brush.Run the fan at different speeds and if the sound gets quicker with the fan,its probably just a bit of debris.The other,the fan wont run as well and may may need replacing when it gives up and wont work
Jun 29, 2009 | 2002 Mazda MPV
Lg 1030hr excessive ping noise
COULD BE ALOT OF THINGS BUT MY FIRST GUESS IS THE FAN SCREWS THAT HOLD THE FAN MOTOR COULD BE LOOSE CAUSING IT TO RATTLE ON START UP OR SHUT DOWN BUT REALLY NOT MAKING TO MUCH NOISE AS THE UNIT IS RUNNING. CAN YOU DESCRIBE THE NOISE BETTER? IS IT SCRAPPING LIKE A SCRUB OR KNOCKING LIKE HIT HIT HIT HIT?
Nov 23, 2007 | Heating & Cooling
Gateway MT3705 Notebook Logo
87 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
