Question about Refrigerators
I have a KitchenAid Supra refrigerator, KSRS25F, it is now 8 years old. Yesterday it lost ability to freeze and cool. Both fans are working fine, no frost on coils, and cleaned bottom coils. Is this the compressor? And are we looking at BIG $$ to fix?
  • trj84054 Feb 09, 2009
    Thats what I was affraid of.... By the time all is done, closer to $800! No mor KitchenAid, looking a the bottom freezers, LG, Samsun and Kemore...
    President:
  • 1,902 Answers
Yes this would be the compressor and they run with a technician roughly 600 dollars. There are two things that will cause a Refrigerator not to cool or freeze, the coils being clogged or the compressor is shot. In this case the compressor is gone. Better to just get a new frig
Posted on Feb 09, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 09, 2009
    LG is one of the better on the market at this time, making a quality product
We moved our Kitchenaid refrigerator down the steps to the basement using a dolly and now its running constantly.
I can't think of any reason moving it would cause that problem. How are your door seals? Are both fans(evaporator fan in freezer and condenser fan at compressor)working? Did you give it 24 hours for temps to stabilize?
Oct 16, 2017 | KitchenAid Refrigerators
Refrigerator/freezer stopped cooling/freezing yesterday. Lights are on inside and 8 hear the fan running in the freezer but no cold air. Tried powering off and also unplugging to see if it would reset...
possible failure of defrost mechanism causing ice to build up behind back of freezer preventing air flow into freezer and fridge. Try turning it off for enough time for ice to melt if cause.
if this is issue the repair man will need the ice half melted to be able to test the thermistor that senses the ice buildup.
Nov 06, 2017 | KitchenAid KSCS25FKSS Side by Side...
Yesterday we had a very strong odor in the house that could be described similar to bleach or ammonia; it burned the nose, was stronger downstairs and we lost the ability to smell it after some time unless...
It sure sounds like the coolant leaked out. It's tough to decide whether to repair it or replace it. Refrigerators can easily last twenty or thirty years, or longer. On the other hand, if you call in a repairman you run the risk of it being a serious problem that would cost several hundred dollars. If it were me I would opt for repair, after checking to find someone with reasonable prices.
Good luck,
genetuck
Feb 13, 2011 | KitchenAid KSRB25FKSS Side by Side...
My KitchenAid KBRS22K bottom mount refrigerator is eight years old. Was working fine, but now the refrigerator does not cool, but the freezer stays cold. The fan seems to work and the coils have been...
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
May 19, 2009 | KitchenAid KBRP20EMSS Bottom Freezer...
Freeze works fine, food side at 50 degrees.
Is there a fan that blows air over the cooling coils in the freezer? Not sure if side-by-side fridges have this. This was the reason for my top freezer / bottom fridge. Air was not being blown around the freezer and down into the fridge.
Feb 19, 2009 | KitchenAid KSRS25IL Side by Side...
KA KSRS series lost cooling in refrig only
Check for frost accumulation in freezer or no freezer fan
Jan 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
8 year old Kitchenaid not cooling
the floor has no control over the fridgr or the way it works.you said its 8 years old youve already replaced the compressor once so maybe it time for e new fridge.
Sep 01, 2008 | KitchenAid KSRG22FK Side by Side...
Side by Side, Fridge is freezing at lowest setting
Is you fan in the freezer working I would check it first . if not check for power to the motor ... if you have power replace motor...
Sep 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
FRIGIDAIRE REFRIGERATOR PROBLEMS
Freezer stayed cold but upper compartment wouldn't. Freeze started having problems with staying cold. I just paid $377 to get the two year old evaporate fan replaced. It is located inside the frig behind the panel in the freezer compartment. It took about 15 minutes. Seems this part is part of the evaporator system but not covered by anything other than the first one year warranty. Problem solved but what a ripoff from Kitchenaid.
Jun 21, 2008 | Refrigerators
Refrigerators Logo
276 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
