Question about Kenmore 659 Electric Dryer
Kenmore Electric Dryer Can't replace heating unit
I have a series 90 Kenmore electric dryer. I found a bad thermal cutout and replaced it, but cannot re-connect the heating unit to the vent pipe in back. Any tricks of the trade?
  • paccampo Feb 09, 2009
    Thanks for your note, but I don't quite understand it. Perhaps I used the wrong terminology. Using terms from the parts manual, I can't get the heater box(3392537) to plug back in to the air duct assembly (697354).
  • 360 Answers
I removed the deflector and duct from outside the house, disconnected the hose, attached the hose to the dryer, passed the hose through the wall as the dryer went back in, then reattached the hose to the duct/deflector and reinstalled the duct/deflector
Posted on Feb 09, 2009
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore 90 Series electric clothes dryer thermostat fuse had no continuity. Replaced the two fuses the parts place sold us. Turned it on after repairing, did heat up but then blew out the same thermostat...
I would say a venting issue, here is a thread, hope it helps Tim:
http://forum.appliancepartspros.com/dryer-repair/19493-dryer-blowing-thermal-fuses.html
Dec 23, 2010 | Kenmore 659 Electric Dryer
My Kenmore electric dreyer does not heat? Vent is not clogged and blowing out freely. I have replaced the thermal Fuse, and the Multi temp switch kit and still no heat? The model No. is : 96573220 Kenmore...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Kenmore Dryers
I need to get to the thermal fuse in my Kenmore 90 Series electric dryer model # 110.66902690. I took off the bottom front panel and can't find it...I'm really not even sure what it is I'm supposed to be...
ok the heater is on the right side of the unit standing from the front the thermal fuse is located behind the thermastat should be round black objects that have to wires going to them it is recommend that if you have a bad thermal fuse you replace your thermostat wich is the bigger round plastic also might want to check your vent out of the house for a restiction
Jun 02, 2010 | Dryers
Need help with gas dryer Kenmore 90 series serial #MK0211114 the gas does not ignite electric is working fine
This could be several things thermal fuse,hi limit thermostat,flame sensor, ignitor,or coils. There is a video on troubleshooting a gas dryer at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting procedure. It is a different model but troubleshooting will be the same. You could also check the video on the electric heating element replacement that is a kenmore 90 and most of the parts will be the same. That one will give you a good idea of what thermostat is what.
Mar 24, 2010 | Kenmore 73952 Gas Dryer
29'' Kenmore electric dryer series 110 not heating up
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 03, 2009 | Dryers
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
Kenmore 659 Electric Dryer Logo
117 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
