Question about Hisense TL1700 17 in. LCD Television
Bad picture on some channels
Very grainy picture on some channels, others come in clear. I am using Comcast cable service with other tvs on same line work fine. Is it the coaxial cable that is bad?
  • 257 Answers
Hi, Sounds like the splitter that allows the cable to go to other tvs might have a problem or there is an old filter somewhere that needs to be removed. Check the splitters and make sure they are the right type and you don't have one that says "in" and out to UHF of VHF but tv 1 tv 2 ect and that if it says anything about band like 800 or 900. If you need further help let me know what these splitters have printed on them. Good Luck!
Posted on Feb 09, 2009
I hooked up my proscan to comcast cable, i can just get first 13 channels.i tried going into settings and doing channel search, it will only clickon analog, not digital channels what can i do to get the...
Cocast may have only transmitting NTSC Ch 2~13 only for your area, to get more channel you may have to use Comcast cable box, I am in bay area, I can get 2~35 for basic plus service, I can get 2~13 for the most simple service for less money. What is your serivce level you are paying for?
Your TV also anly has NTSC tuner, there is no QAM or ATSC turner.
TV SPEC; http://reviews.cnet.com/flat-panel-tvs/proscan-26lb30qd/4507-6482_7-33403393.html
You may have to call Comcast.
Mar 09, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Channels 2-6 picture is bad, but all others are OK
If this TV is connected to cable TV and you are using a cable box then the cable system is at fault. If you are connected to cable TV with no cable box then look at the pictures on other TV's in your home if you have another TV. If they look fine and are small enough to move around. Move the TV and connect it to the cable outlet where this TV is connected and then examine those channels again. If they are grainy then a call to the cable company is due. They can use a signal checker to see what the signal levels are at that outlet for any given channel range.
Mar 02, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
No sound on some channels, some channels have wrong sound for pic
The SAP feature has been turned on. Look for a button that says SAP or go thru the audio menu and turn it off.
Apr 09, 2009 | Televison & Video
Poor picture quality on certain channels only
You could try moving it to the other room to see if the connection is bad. Better than taking to the store just yet. If the picture is still bad at both connections I would just bite the bullet and take it back and exchange it while its free.
Hope this helps and let me know if you need more ideas.
Mar 31, 2009 | Televison & Video
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
Cannot get channel 2 clearly
Normally grainy pictures are a result of poor ground connections, although usually for more than one channel. Check the cable connections first. Otherwise all I can suggest is to have the tuner replaced.
Dan
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Grainy picture
Greetings israelmaker,
In order to receive true high definition television, you will need a high definition cable box. Basic channels are going to look more grainy and not as clear overall even with an HD box, however you won't be able to view or decode the actual HD channels without a box.
In addtion, what type of cables are you using to hook up your existing box? This can have a substantial impact on the picture you see.
I hope some of this helps.
Dorothy
Go Ahead. Use Us.
Jul 28, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Hisense TL1700 17 in. LCD Television Logo
200 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
