Question about iRiver T30 MP3 Player
IRiver Music Manager showing "disconnected"
I have been using an iRiver (don't know the model) and have been able to use Music Manager to convert to mp3 and put these files on my computer for later upload to a podcast service. I have a T30 Rose now. When I open iRiver Music Manager to perform the same action, it always shows that the T30 is "disconnected". I have downloaded Music Manager and can't get that program to "see" the T30. What do I do? I no longer have the other iRiver recorder and my T30 is somewhat useless if I can't convert files for upload through Music Manager. HELP!
5 Suggested Answers
SOURCE: No longer have podcasts file and icon
I decided to lose what I had in the podcasts file, and installed a new empty file and named it podcasts
Posted on Jun 27, 2008
SOURCE: IRIver IFP700
It might be because you do not have sufficient administrative privileges for your user account. That is why mine wont work.
Posted on Oct 09, 2008
rajeshgopa
SOURCE: file check error in
Hi. this is rajesh gp from sivagangai. it is very easy to solve. just long press your iriver menu(M) and goto settings -> advanced -> format. then copy any music files from your pc then enjoy with your songs. [gprajeshmca@gmail.com]
Posted on Jan 05, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: My iriver T30 says it's on 'hold' when the hold botton is off
I would reset the player first. As long as you are absolutely sure that the hold button is not engaged, then resetting the player ought to make the hold message disappear. If the reset fails, plug the iRiver into the computer to see if the computer will recognize the player. If it does, then go ahead and update the firmware on the player from iRiver's website - it will have the side effect of fixing your issue.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
trials78
  • 28 Answers
SOURCE: My iRiver T30 has always had difficulty
There may be a driver issue as I've personally had problems with my iRiver IFP mp3 player and would try to load the driver every time I connected the player to my Windows based computer.
Assuming you have a Windows based operating system, I would completely uninstall the iRiver Music Manager in add/remove programs in the control panel, restart the computer and try reinstalling the program again.
Posted on Nov 07, 2009
I have an ifp 790 iriver player. I have Windows 7. Iriver music manager does not work on Windows 7. I tried the compatability factor on Windows 7 and it does not work. Please help me! I need to be able to...
What type of Windows 7 do you have? Is it 32-bit or 64-bit? If you have 32-bit, then iRiver Music Manager should work. However, if you have 64-bit, it will not work, according to a phone call I made to iRiver several months ago. I had the same problem as you, and so I called iRiver and that is what they told me, and then I exchanged my 64-bit computer for a 32-bit computer and now the iRiver Music Manager works.
Sep 25, 2011 | iRiver iFP-790 MP3 Player
I need the software from the CD. I loast my CD and i have anew PC. I want to remove the audio files on my iriver IFP-795
Please download the iRiver Music Manager from the following link.( http://local.iriver.com/usa/lounge/loungeView.asp?selectPart=cateCode&findWord=01&sno=859&page=1&cateCode=01 ).The detailed instructions to transfer audio files between your player and computer is explained below.
1.After installation of iRiver Music Manager, please drag the file as follows
2. After dragging file you can see the below window
3. If you want to make another folder in your device,please take a look at the image below
Please don't forget to rate me if satisfied.........
Jun 04, 2011 | iRiver iFP-795 MP3 Player
I need desktop app to manage music for iriver
Support for the iRiver IFP-899 is on next site:
http://www.iriver.com/flash/index.asp?code=0302
MANAGER connection type
In the second column next to GO, enter the word manager or select POPULAR KEYWORD.
On the page right side a list shows up.
Select the iriver music manager to see the information how to download and install the software. The manager for the computer matches the manager firmware in the player.
Need more help ? Just post a comment.
Dec 26, 2009 | iRiver iFP-899 MP3 Player
Where can I get the driver and music manager for my IFP-799 ?
iRiver IFP-799 is a IFP-700 series player.
Making transfers to the device can be done in either UMS or Manager mode.
UMS firmware matches with seeing the player as a removable disk in Windows Explorer and is also used for updating firmware, using iRiver PLUS software.
Manager firmware matches with iRiver Music Manager software.
When needing the Music Manager go to next site and enter the word
manager in the second column next to GO:
iriver music manager ( Ver. 3.21 ) shows up: click the item and read
the instructions for download and installation.
How to update the player's firmware
in MSC mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=47
in Manager mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=252
Dec 25, 2009 | iRiver iFP-799 MP3 Player
I'm looking for for a driver for i-river MP3 IFP-790 and can't find anything right on the web. would appreciate it if someone could direct me to a download link, tnx
IFP-790 can be accessed in UMS and Manager mode:
UMS mode
For firmware upgrades iriver PLUS3 must be used.
Download iriver PLUS3 going to this site:
http://www.iriver.com/index.asp
Click Support on the left side.
Select Download in the second column.
Select "Download iriver PLUS3" in the page: allow download (when blocked / sometimes download has to be repeated).
The size of the iriver PLUS3 download is 59.3 MB.
iriver PLUS3 can also be used for music transfers in UMS mode.
Manager mode
For Manager type connection the iriver music manager must be downloaded and installed.
Go to the support site:
Select Support in the first column.
Enter the phrase 'music manager' and click GO:
download 'iriver music manager (Ver 3.21)' [ 28 MB].
Sep 29, 2009 | iRiver iFP-790 MP3 Player
I can't find a software for my iriver model-ifp-790
try this: http://iriverinc.com/support/ultra/700.aspx (copy n paste into search bar)
>>click on: iriver music manager for PC
OR
if you have MAC computer click on: iriver music manager for MAC
>>then click on: iriver manager 3.16
>> click on RUN NOT SAVE -even though it says click on SAVE, it WILL NOT WORK
>> it will then begin installing
>>click on: RUN a second time if nessecerly
>> then click on the iriver icon on your desktop and plug your mp3 player into your computer
hope this helps! :-)
Jul 11, 2009 | iRiver iFP-790 MP3 Player
IRiver iFP-180T drivers
you must download the iriver music manager from their support site. the music manager automatically installs drivers via info on their site...
iriver Music Manager V3.21
Supporting models of iriver music manager is iFP-Series
(Manager mode ) and N10.
If you want to switch connection mode (iFP-Series only)
from MSC to Manager version,
please click here.
(Device Driver included and automatically installed)
Upgrade Features
-. Compatibility with Windows vista.
Here is a way of how to transfer music files from
your PC to your device by manager.
Jan 03, 2009 | iRiver iFP-180T MP3 Player
File check error in
my iriver t20 shows on display "file check error" and all my folder are disappeared.please help me to solve the problem. thanks for your assistant.
Dec 14, 2007 | iRiver T20 MP3 Player
Getting music off Iriver
Bronte,
When you change your firmware from the "manager" version to e.g. the Firmware v1.85 UMS version, you will no longer need to use the iriver manager software to move mp3's around, you can just drop them on or from your iriver. The disadvantages are that:
1. by upgrading to the UMS version, you will wipe ALL your current music, so it will NOT help you right now, only after you have upgraded to the UMS version and placed mp3's on there again. The iriver will behave like an external thumb-drive, so you can use it on any PC without the iriver manager.
2. The UMS firmware will ONLY run in USB 1.0 speeds, so it will take up to 36 minutes to fill the iriver up with 1 GB of music (or in my case podcasts).
Regards,
Robert Ilbrink
Dec 10, 2007 | iRiver iFP-799 MP3 Player
IRIver IFP700
Oct 11, 2007 | iRiver iFP-795 MP3 Player
iRiver T30 MP3 Player Logo
753 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
SmartAviator
SmartAviator
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
