I have had a hoover top loader washing machine,(model-hoover gemini A6516-010) for about 12 years now, and i ve had no problems with it, but recently after coming from about a months holiday ,I switched it on to get our family laundry washed up. but unfortunately the tub would not agitate ,i.e on the normal cycle.and the timer would not go thro its normal motion.so I turned the unit over to have a look and found the brake (locking pawl) was not disengaging from the drive mechanism, and u obviously must be knowing that this brake ,is infact activated by a coil which has to be energised by some switch, could be faulty. so can u pl . help me with this problem. besides also, just 2 note i ,manually moved the timer forward to pre wash rinse, ,this is where brake coil was energised allowing the drum to spin. so i was wondering if the timer is faulty and whether it should be changed.thanks Henry.
    President:
  • 1,902 Answers
YEs the timer is ad and you should replace the timer. You can also just to double check take a volt meter and power on the nit and see what kind of volts you are getting
Posted on Feb 09, 2009
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
How can I open the door on hoover Quattro washing machine.
if its a front loader remove lid and plug u can get the door open from top with a long screw driver and a bit of patiace
Mar 01, 2015 | Hoover Washing Machines
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Free download user guide for hoover washing machine gemini 6kg model a6564
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is Hoover web site for user manuals
http://service.hoover.co.uk/manuals/
Jul 06, 2009 | Washing Machines
Hoover 500 ma top load washing machine manual & specifications
FRIEND,
BUY SPEED QUEEN FRONT LOADER. IT ONLY USES 13.9 GALLONS OF WATER PER WASH!!!!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Hoover Washing Machines
Hoover top loader washes &
Check the lid safety switch.
Apr 01, 2008 | Washing Machines
Hoover elite 930 top loader washing machine
I am a recently retired appliance engineer of 20 years start with checking the other solenoid, the conditioner one, it may be that that is not working, and double check the cold one, remove the two wires and check for a circuit, it may be actually filing up initially with hot water without realising it, always work with safety remove the plug before removing panels etc if i have helped rate me please
Sep 09, 2007 | Washing Machines
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
