Question about HP OfficeJet 7410 All-In-One InkJet Printer
Scanner failure when faxing of coppying
When I try to use the fax or copy function, document pulls half way in and stops with the message scanner failure. This is not a feeding prolem.
Please note that the scanning works just fine. I suspect that there is a control which does not activate the scan operation with those two functions. Additionally,I hear what sounds like a grinding gear noise at the point where the document stops feeding.
  • xkaybo89x Apr 02, 2009
    I have the same problem at my work with the scanner/copier. Can someone please help? I cannot send out any faxes, and my pile of faxes is getting bigger by the day!
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Posted on Apr 04, 2009
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
When I send a fax, the recipient gets all dark or black sheet. Thinking this was the recipients problem, I faxed again to a different fax number, same thing happened.
To fix the problem you have to check the scanner of your fax machine. It might not be functioning properly. Try to observe the fax machine while sending a document, look at the scanner section and see if the light of the scanner is turned on or lighted. If it's no longer lighted you have to replace it.
Nov 07, 2010 | Sharp UX 355L Plain Paper Thermal transfer...
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Scanner seems to jam when faxing, scanning or coppying
CLEAN THE DOCUMENT FEED ROLLERS ON TOP INSIDE DOCUMENT FEEDER CLEAN ALL ROLLERS WITH MICROFIBER CLOTH MOSITENED WITH WINDEX
Jan 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure
You can copy, but not scan or fax from the flatbed...
You can copy, but not scan or fax from the feeder...
Am I reading this correctly?
Oct 18, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Errors
Hi Jean, The issue can occure only when the HP printer is not gettting enough power supply or the scanner bulb is not getting heated up properly.. You can isolate the issue by directly connecting the printer to wall jack and powerup the printer and try to make a copy so that we can check the copy function as the copy,scannig and FAX use the same scanner bulb to performe all functions.. If the copy does'nt work try to lift the scanner lid and check if the scanner bulb is lit and the scanner machinasium is moving fine or not .. lift the lid and press scan button to check the functionality. If the printer is connected to a surge protector or power strip this will some time fail to provide the required power supply to the printer so connect it to wall outlet and check with the issue.. There is also a FIRMWARE UPDATE RELEASED BY HP to fix the some of the scanner failure and receving faxes issue with HP 6110 All-in-one Here is the weblink to download and install the firmware update just click on the link to open the download page and then click on download and select save to save the patch to computer and run it to install the update make sure that the printer is connected and turn on while installing the patch The link to download: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14700-3&lc=en&cc=us&dlc=en&product=79477&os=228&lang=en Hope this will fix the issue.. If the issue is with the scanner failure message try the instruction in the below weblink: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en Wish you success Jean Regards, Barret
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
237 people viewed this question
Seeker5211
Seeker5211
