I have two harmony remotes. when i try to acess each i keep getting the same one. i have one for my family room upstairs and one for my basement system. i can not acess my basement system
  • 19,396 Answers
Try re-programming the Harmony remote that does not work.
Posted on Feb 09, 2009
  • Ginko
    Ginko Feb 09, 2009
    First try programming again the Harmony that does not work.
    If this is not a programming problem , then the remote may be defective.
    In that case you can call the number listed on the owner manual to get support.
I have a SuperScan 35 inch I have hook a RCA indoor antenna to it and run channel search but nothing comes in help me please
The problem could be with the antenna you got versus the location you live. Indoor antennas are very range limited. Non-amplified models range about 25 miles, while amplified models make about 50-60 miles. Also, you must consider where you live. If you live in an area of heavy building concentration, signal may be limited. Home construction matters as well. Frame houses pass signal better than brick or concrete block homes. Upstairs locations fare far better than basement family rooms.
Nov 01, 2015 | RCA Televison & Video
Have oil heater that we had serviced yesterday. Heater stays at temperature but circulating pump will not send heat to upstairs radiators. (heater in basement) Any advice?
Try putting in central heat and air in your house don't rely on some basement heater then you will have a basement heater for when it get cold
Dec 03, 2013 | Lakewood Oil-Filled Electric Radiator...
Dish Network TV1 remote doesn't work with new TV
Becki Schuurman,
Our remotes can all function independently. If the family room is TV1, then you can definitely program the remote there and have no complications with the TV2 (As long as the frequencies are different). Keep in mind our remotes are not guaranteed to work all types of equipment, but we have many steps and options to get it working.
If you have any additional questions or need any assistance, just let me know here or at thomas.faust@dish.com!
Tommy Faust
DISH Social Media Representative
Aug 16, 2012 | DISH Network IR Remote Control
I live in a three story house my wii is in the basement and my wireless router is on the second floor should my wii pick up a signal...i tried to hook up with netflix and my wii says cant find connection
Hi.
1. Try using it upstairs on the 2nd floor and if it works there you know its a range issue with the router.
To then solve it you could run a cable from the router down to the basement (which is a bit old school but very effective and guarenteed to work) or get a second router or modem and place it in the basement. (for modem you would need a phoneline in the basement)
2. If it doesn't work upstairs, make sure you have the correct connection information for your network and that your network is broadcasting its SSID. If your network is not broadcasting it is what is known as hidden. This means that you will have to enter all the network information manually by following the prompts on the wii console.
Jun 16, 2011 | Nintendo Wii Console
Our remote Harmony 670 turns on both of our TV's same make different model numbers and different rooms
Lots of TVs from the same brand use the same IR codes for on/off, the output of the harmony is strong and can easily reflect off of walls and effect other devices nearby.
Jan 01, 2010 | Logitech Harmony 670 LCD Remote Control
I keep losing my wireless connection inside my home. My modem is in the basement and I want to use my laptop upstairs. I use an N router and have cable internet. My house is also wired with Cat 5 wiring...
Well , the connection upstairs depends on the capabilities of the router that how much coverage it can give for the wireless clients associated.
Since , it is a N-router so try upgrading the drivers for it , the technical term will be firmware.Upgrade the firmware of the router to the latest one and you might have your issue resolved.
Nov 24, 2009 | Computers & Internet
Trane Heater A/C Airflow Control
i had a similar problem, and a six inch duct and inline booster fan didnt help, the room was just to far away from the furnace and ac. to save energy, i use an oil rad in the winter, and a portable ac in the summer, it works great.my house is a back split, so its a common problem. in the summer, all downstairs dampers should be closed to push the cold air upstairs ,as it will come back down anyway and the basement is cooler as it is. so if you have 4 flores, you close the bottom 2. bungalow you close the basement
Jul 22, 2009 | Heating & Cooling
Central Air Conditioning
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
