Question about Uniden EZ-Dial Large Button Corded/Cordless Telephone with Digital Answering System and Caller ID "Announce...
I have a uniden XS 1455 phone. I want to modify the entries in the "speed-dial", and want to get one off the system completely. I've followed the manual faithfully and completely, but cannot seem to make the instructions work. I'm a poor old so-called "Senior", and am completely bamboozled! Can you please, oh please help? I would be so grateful. I've explained the situation to the agent in Dandenong, but he seems utterly useless!! So thanks a lot in anticipation of your help. Kind regards. MIKE POND.
  • mjp2467 Feb 19, 2009
    Dear Uniden,
    Your instructions regarding my problem ARE INCOMPLETE, and I still couldn't do what I wanted.It has taken me all this time to find out what to do, so I'm sorry, but I'm far from satified. I have found out BY MYSELF that I can fix the problem , using the "select" button, also the up/down buttons. Why doesn't someone at Uniden know about this....it's a pretty poor show, in my opinion.
    I told you that I am a "Senior", and these things, unless one is technically savvy, are very hard to solve. Not everyone is a techo nerd, and I'm certainly not!! I'm 69+, and believe me, I'm not just sitting here doing this for the lack of anything else to do!!
    In view of what is, (you must surely, and in all honesty, admit,) a big let-down by your company, I consider that to be "seen to do the right thing", you really should refund my $10. It's hardly a drop in the ocean to such a large company as yours, surely, but to me, it's quite a slice out of my pension. So may I humbly and respectfully request a refund? I would be most grateful, and it would show what a marvellous company Uniden is.....big-hearted and compassionate!!!!
    Kind regards, MIKE POND.
    P.S. If you can arange a refund, I will tell you how I solved the problem...deal or no deal? Thanks. You should note that there are absolutely no instructions at all in the handbook about this problem.
  • Uniden Master
  • 19,396 Answers
Ensure that you have saved settings after modifying the entries.
Posted on Feb 09, 2009
  • Ginko
    Ginko Feb 09, 2009
    Follow the instructions below:
    "Using the Speed Dial Memory
    Storing Numbers in Speed Dial Memory
    Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
    memory. To store number in memory:
    1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
    2) Use the keypad to enter the phone number.
    (To enter a 2-second pause between numbers, press [redial/
    pause]. Each pause counts as a digit. )
    3) Press [memory] again.
    4) Select the speed dial location where you would like to store the
    number ( [0] to [9] ). You will hear a confirmation tone indicating
    that the number has been stored.
    NOTE:
    • Storing a number to a speed dial location will
    overwrite the any previously stored number without
    warning.
    • When storing numbers into memory and the handset is idle (i.e., no key is
    pressed) for more than 0 seconds, it will beep rapidly, and then the phone
    will return to standby.
    Dialing a Stored Number
    1) When the phone is in standby, press [talk], and listen for a dial tone.
    2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
    you want to dial. (If you enter a digit that does not contain a stored number, the
    handset will beep rapidly, and the phone will not dial.)
    Chain Dialing
    The speed dial memory is not limited to phone numbers. You can store any number (up
    to 20 digits) that you need to enter once your call connects. This is referred to as Chain
    Dialing. An example is a frequently refilled prescription number. Store your pharmacy
    phone number in one speed dial and your most frequently refilled prescription number
    as another speed dial. To use, once you ring your pharmacy's automated prescription
    line, simply press [memory] and the speed dial number where you stored your account
    number.
    Erasing a Stored Number from Memory
    1) With the phone in standby, press [memory] twice.
    2) Press the number of the speed dial entry. A tone indicates that the stored number is
    erased from memory. "
    From Uniden
Can i add 3rd handset to uniden xs 1455+1 cordless phone
if you can get the exact model as the existing hand set it should not be a problem
just follow the installation process to get the base to recognize it so that it connects
Dec 05, 2015 | Uniden Cordless Phone
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
I've tried to follow instructions on Pg.9 but when the display has the following Delete Entry, there's not button to push or Arrow, I press Clear (for Delete) and nothing happens. It is very...
If you just want to dial a number in the phonebook, press up/down to find the entry you want then press TALK/FLASH. Look at page 10 in the manual, under "Using the Phonebook".
Aug 26, 2011 | Uniden DECT1363BK Cordless Phone
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Speed dial
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows:
1. Copy all address book entries from Sim to Phone Memory.
2. Delete all Sim Address book entries.
3. Switch Address book source to Sim.
3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial.
4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Jun 20, 2009 | Samsung S8300 Ultra Touch platinium-red...
How to modify details in system speed dial
Easiest way would be to log into the programming tool and make the change there. However if you do not have access to the tool you should ask you installer to provide you with it. There is a user mode that will allow you to change only the Speed dial numbers and text.
Apr 09, 2009 | Panasonic KX-T7630 Corded Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
NOTE:
warning.
Chain Dialing
number.
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Speed dial on uniden
When the phone is not in use, press and hold the number key (0-9) that is assigned to the phonebook entry. Press flash on the handset to dial the number.
Apr 23, 2008 | Uniden DCT756-3 Phone
Uniden EZ-Dial Large Button Corded/Cordless Telephone with Digital Answering System and Caller ID "Announce... Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
