Question about Road Gear RG-CD411 AM/FM Receiver with CD and Flip-Down Detachable Face, 160 Watt, 3 preset EQ (RGCD...
WHEN I PUT A CD PLAYER IN THE DISC PLAYER IS SAYS ER07
WHEN I PUT A CD IN THE CD PLAYER IT SAYS ER07
  • Anonymous May 02, 2009
  • Anonymous May 24, 2009
    Put CDin unit and get display "ER07"
The only thing my eclipse is showing is "DISC" it does not work at all i dont know what to do.
you the the frist cd that was ever put it there. that cd had a security code burned on to it the frist time it was put in the cd player. thats the only way you can get that brand to work.
Nov 12, 2009 | Eclipse CD3422 CD Player
When I put a audio disc in my cd player. I get on
this is a error code for can't read disc or bad lens. what you need to do first is try a cd cleaner in it first and then if not you will need to have it repaired because the lens can't read data.
hope you get it going with the cleaner! good luck
Nov 03, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Cd player not playing
I would go to walmart and buy the disc....its like $10 and made by phillps. After you just put it in your disc slot and it plays you should hear some guy tellin you that its cleaned....this happened on my 2001 Jeep Liberty so it should work
Oct 06, 2009 | Jeep AM/FM Cassette with CD Changer...
When i put a cd in my DRX7575z cd player it comes up with error 6 i have radio function but no cd
Error 6 means your laser isn't reading disc. Needs replaced pick up laser. I would try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist, you have to go to fix it to a specialist.
Sep 23, 2009 | Clarion DRX7575z CD Player
Road Gear cd player says er07 or er09.
Hey Rachelle.. Sorry to say, but Road Gear is an off brand, and they don't hold up well at all. It sounds to me like the laser it's self has gone bad, and unfortunately not worth fixing.
If you want an inexpensive cd player that will last for a while I recomend Kenwood KDC138 they retail for arround $90, and do a decent job. Nothing fancy, but they do have a front input for MP3 player, or any aux source.
Aug 07, 2009 | Road Gear RG-CD411 AM/FM Receiver with CD...
Cd player gives me a error code 4
The player doesn't like the brand of CDR your playing. Try using just a CD burner instead of a combo CD/DVD burner2_bing.gif. Also use Verbatim Pastel brand, because the player recognizes these discs easier. Also, it wouldn't hurt for you to run a commercial disc laser cleaner through this thing to clean the optical lens. Burn music using Nero software because its easy and the best.
Mar 13, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Ate my CD
looks like the tray is offline so basiclly its not reading the first disc because its far away from the eye so by putting another disc in and it reads it because the eye is close enough to read it .  u may have to open the player up to get the first disc out.  good luck.
Oct 24, 2007 | Pioneer DEH-P690UB CD Player
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
TOC Error
I had the same problem with my KDC-M7024 CD player. All I done was put a cleaning disc into the player and let it play for 2-3minutes. The disc has a small cleaning brush on it which spins around like a normal CD would and as the bristles pass over the laser it removes any dust.After that it worked fine but i still have to run the disc through every 3-4 months or the problem persists.
Dec 07, 2006 | Kenwood KDC-M7024 CD Player
Car Audio & Video Logo
49 people viewed this question
Top Road Gear Car Audio & Video Experts
xxxxxx xxx
Are you a Road Gear Car Audio and Video Expert? Answer questions, earn points and help others
