Question about Samsung SC-D103 Mini DV Digital Camcorder
Wont let me record! Flashes "Protection!"
I have a samsung mini DV NTSC which worked just fine no problems. One day I tried to use it and with a new tape or any tape for that matter...it will not record. It flashes the word "Protection!" And when I check the tapes...its on the right setting that allows them to be recorded on. so that cant be the problem. HELP!!
  • Anonymous Mar 08, 2009
    protection flashes does not let me record
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Posted on Nov 30, 2010
Got a brand new samsung d381 camcorder and when you playback recordings there are horizontal green lines across the screen and no sound, what am I doing wrong? or should I send it back as faulty? I have...
SOUNDS LIKE YOUR HEAD IS STUCK OR YOU NEED A DRY CLEANING TAPE RUN TROUGH. SOMETIMES WHEN U USE OLD TAPES THEY ARE DUSTY AND THE DIRT CLOGS THE HEAD. TRY A GOOD TAPE CLEANER
May 28, 2009 | Samsung DouCam VP-D5000i Mini DV Digital...
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony dsr-45 tape
It is:
Sony cleaning cassette DVM12CLD you can buy it from ebay at 15 pounds. click on the following link:
http://cgi.ebay.co.uk/Sony-DVM12CLD-MiniDV-cleaning-cassette-in-Blister-DVM12_W0QQitemZ370257959235QQcmdZViewItem
Aug 07, 2008 | Sony DSR-45 Mini DV VCR
When I try to play PAL tapes, there is no picture
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Jul 31, 2008 | Sony DSR-11 DV / Mini DV VCR
Samsung Mini DV camcorder (Protection-Problem)
SOUNDS LIKE THE TAPE TRANSPORT IS BAD. IT WILL EAT YOUR TAPE SOON. YOU WILL NEED A NEW TRANSPORT OR A NEW CAMCORDER ...SORRY
Dec 14, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Won't play DVCAM, will play Mini DV
it is probably matter of dirty guide so the timecode stop reading try a wet head cleaning tape to play it there regards please don't forget to rate ,thx
Feb 20, 2007 | Sony DSR-45P DV / Mini DV VCR
Pal on SC-L700
This model will play only NTSC. NTSC is the television broadcast system used in the USA (and a few other countries) Tapes of any format than NTSC will not play properly in this camcorder.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung SC-D103 Mini DV Digital Camcorder Logo
332 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
