Question about Amana SXD524VW Side by Side Refrigerator
Amana side by side (SXD23VL) water dispenser = no water.
I have a water and ice dispenser. Literally, one minute it was working, i changed the filter of the CLean n Clear fitration system, and pushed the water dispenser and all i got was the residual water left in the tube and then a big burst of water then nothing...any help is appreciated.
  • pprmntpatti Mar 28, 2009
    I have had a tech out twice and the first one said the water line was frozen in the door, so I defrosted freeze and heated door...nothing. The 2nd tech came out and said the water wasn't even reaching the door. He said the resevouir was frozen. So I heated the water tank and still I have no water in the door. I can hear the motor run, the filter is not plugged. It still won't run with a filter dummy in it. What could be the problem?
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Posted on Nov 12, 2006
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
  • 219 Answers
SOURCE: amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Posted on Mar 19, 2009
  • 135 Answers
SOURCE: I have an Amana SXD23VL side-by-side refrigerator
Your water presure to the frige is too low. Do you have a reverse osmosis water system hooked up to it?
Posted on Sep 01, 2009
  • 220 Answers
SOURCE: Amana SXD23VL hollow ice
Take the line loose from the back put it in a bucket turn it on and see how the pressure is,if it trickles out your problem is in the water pressure.otherwise you have a bad solenoid valve.
Sep 01, 2009 | Refrigerators
I have an Amana SXD23VL side-by-side refrigerator and the ice cubes are hollow. Why?
Sep 01, 2009 | Amana SXD524VW Side by Side Refrigerator
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser not working
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Amana French door Refridge-water dispence inside the door not working
pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
Jan 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Dirty ice
Did you change the water filter recently? If so, you may have some air in the lines which can be purged with a few minutes of dispensing water through the front.
Nov 02, 2007 | Amana ARS9265B Side by Side Refrigerator
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
223 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
