Question about Singer 5062 Mechanical Sewing Machine
I have the Singer 4562 and need more bobbins
I have the manual, but it does not tell you what size of bobbins to use. I bought the pre-threaded class 66 but am not sure if this will work.
Thanks
  • 2 more comments
  • cpardivala Feb 09, 2009
    Thanks a million!!!
  • Farhat Kalsoom
    Farhat Kalsoom Feb 04, 2013
    Iam using class 66@singer4562 successfully.the metal one no problem since a year so far.
  • Anonymous Mar 16, 2014
    need bobbin size for H/class model
  • Anonymous Mar 28, 2014
    what size bobbin?
    Scholar:
  • 69 Answers
The machine does take the class 66 bobbins.
Posted on Feb 09, 2009
How to thread the bobbin on a singer electronic 4562?
Do you need to wind the bobbin? If you just need put in the bobbin, make sure that the needle is in the highest position and that the presser foot is up. Slide open the cover by moving it towards you. Pull about 4" of thread from the bobbin and hold the bobbin such that the thread is coming off in a counter-clockwise direction. Put the bobbin into the bobbin case and secure the thread in the notch near the center bottom of the bobbin case. Next guide the thread into the notch to the left (near 7 on an analog clock). Hold onto the thread and slide the cover closed. To bring up the thread, make sure that the needle is threaded as well. Turn the hand wheel slowly towards you while you hold the needle thread with your left hand. Turn the wheel until the needle comes back out of the needle plate. Pull gently on the needle thread. You should see a loop of thread around the needle thread. Gently untangle this loop until you get to the end of the bobbin thread. Pull the needle thread through the opening on the left side of the presser foot. Then pull both threads to the back of the machine.
Most Singer sewing machines are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 4562 is http://www.singerco.com/uploads/download/435_5_8_10_16_22_dial.pdf . The details and images for winding the bobbin is on page 13. Inserting the bobbin and raising the bobbin thread is on pages 15-16.
I hope this helps.
Sep 23, 2015 | Singer Sewing Machines
Do not have manual need to knowhow to use
If you had provided the brand and model number, we could probably help. Other than that, Google your machine and model number and see if there are any manuals available.
May 23, 2015 | Sewing Machines
Why does the top thread sometimes picks up the hook and then picks up bobbin but bobbin then crosses over and makes a mess? Wont work
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? n
May 21, 2015 | Sewing Machines
Machine well not work with the quilting foot what can I do
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
What size bobbin does a singer 5050 use?
If it's a drop in bobbin machine, it's best to use the class 66 bobbns. The sides are rounded so that when the hook grabs the thread and pulls it around it can slide over the bobbin more easily
Aug 12, 2014 | Singer 5050 Mechanical Sewing Machine
I have a model 5062 and need more bobbins.
The Class 66 bobbin is the correct bobbin. The Singer part number, 172336, is specific to the 10 pack of their bobbins. This site, http://www.sewingpartsonline.com/bobbins-singer-apollo-class-66-172336.aspx , gives more details on the sewing machines that use the bobbin.
I hope this helps.
Jan 02, 2013 | Singer 5062 Mechanical Sewing Machine
What size # bobbin do I need for Singer 328K Style-O-Matic?
The Singer 328 is a class 66 machine it sounds to me like you had a bobbin that was billed as a 66 but was something else. Or you had it in upside down.
Aug 18, 2012 | Singer Sewing Machines
I have a Singer Sewing Machine Model 4562. The machine will not pick up the bobbin thread. I was told by a local sewing repairman that the timing was off. Can anyone tell me how to fix it myself, a
have you tried changing the needle? usually flat side goes to the back of the machine
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
try these sites about timing
youtube
fixsewingmachines.com
sewusa.com
Apr 10, 2012 | Singer Sewing Machines
My bobbin on my Singer 4562 keeps bunching up the threads, can you help?
If you have the black bobbin case you must make sure you use only a good mercerised thread, there should be enough gap between the edge of the bobbin case and the silver adjuster to allow the thread to pass through, if there is not then you must slacken off the two screws and move it over a fraction.
Aug 11, 2011 | Singer 2732 Mechanical Sewing Machine
Singer 5062 Mechanical Sewing Machine Logo
603 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
