Question about Dryers
How do I reverse the door
I recently purchased a maytag ''9000'' series (model no. mede900vj) is there a set of instruction ssomewhere to illustrate how to reverse the door?
  • 640 Answers
Its with your owners manual,,,look for the installation instructions..onthejob
Posted on Feb 09, 2009
Machine running reverse
Can you tell me which model Elna? Have you owned it for a long time, or is it a recent purchase? If it is an older machine, i.e. a little Lotus ZZ, or one of the Star Series, I suspect that your stitch knob has simply been turned the wrong way. I own a variety of Elnas, about 10 in total, so if you can be more specific about the machine, I may be able to give clear instructions.
Mar 09, 2016 | Elna Sewing Machines
Maytag 9000 washer series manual
the hinge on the door is broke the door is about fall off
Feb 03, 2012 | Maytag Washing Machines
I have a Maytag Neptune Model #: MAH5500BWW Serial #: 74920520ZZ The door refuses to close. If I slam it a few times, it eventually closes, locks, and it washes fine. I was considering replacing the lock...
If definitely sounds like you have a door latch problem. Slamming the door repeatedly, however, is probably doing more harm than good. You may be able to get the door to work intermittently for now, but eventually, the lock will stop working altogether.
You are correct. The part numbers ARE based on the Serial Number (series) when it comes to Maytag appliances. If a series is listed next to a part (series 10, for example), the part applies to all appliances that have a serial number beginning with "10" or higher. If an additional series is listed (20, for example), the part applies to all appliance that have a serial number beginning with "20" and higher.
EXAMPLE:
Series 10 (serial numbers beginning with "10 to "19")
Series 20 (serial numbers beginning with "20" to "29")
Series 30 (serial numbers beginning with "30 to "39")
So...using YOUR appliance serial number for this example, if you had a part that had several series listings, you would use the one that matches nearest to your serial number. Say, for example you had a door latch that had three different versions (series 10, 20 and 30). You would use series 30, as the number is the closest to the beginning two digits in your serial number. If your serial number began with "19", for example, you would use series "10", because the first two digits in your serial number do not exceed "20". If only one series number is listed, or if no series number is listed, it applies to ALL washers under that particular model number regardless of serial number. Confused now? So am I.
Based on the information you've provided, the part number for a replacement latch assembly for your washer is: 22004435.
You can purchase replacement parts at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also inclide helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. There are also helpful wiring diagrams included on some sites. Prices vary, so shop and compare.
NOTE: If your model number is not listed on some sites, use the part number from the Sears site as your search criteria. Sometimes certain model numbers do not always appear on parts websites (due to the appliance being too old, recently added model, etc.), but the part numbers generally will, because many parts are interchangeable between model numbers. If you have any questions, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Can I change the side the door opens?
Unfortunately you cannot reverse the doors on this model. There have only been two front load washers that I know of that had reversible doors, the maytag neptune and amana front loaders. Your matching dryer for this model, I believe has a reversible door, but you'll have to purchase a kit to do it. IF needed maybe you can switch the dryer and washer locations to make them more accessible?
Sorry, and good luck to you!
Jul 03, 2010 | Whirlpool GHW9100L Front Load Washer
I have a maytag 9000 series washer showing an f 24 error. What is this error
go to the maytag web site and type in model/serial number it should be on the door,type in the code and they will tell you a code to fix yhe problem.adrian,,,,
Jun 29, 2010 | Maytag Washing Machines
Seal is ripped
Yes, the door seal (bellow) can be purchased and replaced. The following link explains step-by-step how to change the door bellow on a Maytag Epic front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following web sites:
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The firsat three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful. NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions will apply.
Apr 30, 2010 | Maytag EPICz 3.7 cu. ft. Washer
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Oven racks for Maytag CWE 9000 ACB
HI, simply click on the link provided below to be directed to the purchase page. You can order your new replacement rack on-line, if you wish.
CLICK HERE-OVEN RACK PURCHASE PAGE
Nov 07, 2009 | Sears 61301 Gas Kitchen Range
Dryers Logo
349 people viewed this question
Top Dryers Experts
