Question about Samsung Televison & Video
Convergence Problem How can I find the samsung part number for a convergence amp IC the number on the two IC's are STK392-040.
    Scholar:
  • 150 Answers
Hi, the "trick" to this is you don`t need the samsung part number because the stk 392-040 is actually made by Sanyo, call this number and you`ll get exactly what you need 1-800-575-9833 there in Orlando, Fl. and only sell original Sanyo stk``s which is what came in your tv, make sure you check for burnt resistors around those stk`s before installing and powering up your set with the new stk`s, video-tek
Posted on Feb 08, 2009
Samsung PCL542R the Timer light is on and TV will not turn on
TV is in shutdown, may be caused by a shorted convergence amp IC. Also could be caused by any short in secondary B+ supply. Unplug supply to converg amps, if TV comes on, but out of convergence then you have a shorted IC, STK-392-010
Mar 10, 2009 | Televison & Video
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Samsung hc-p4752w
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
My screen have some red lines
good luck
Mar 11, 2008 | Samsung HC-P4752W 47" Rear Projection...
Auto focus convergence on blue doesnt' work
this is an idication that eather the convergence ic's or convergenc ic output resistor have blown
Feb 16, 2008 | Samsung HCM422W 42" Rear Projection...
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung 42" projection green and only green out of focus? Bulb? Tube? IC?
Just had new Ic?? Meaning single?? The symptoms you're describing are a convergence failure. That unit takes Stk392-040 Sanyo Ics and be aware there are a ton of Chineese knock-offs out there that can cause you real trouble, so purchase them from only a reputable part distributor... You need to change both amps, test all 3.9 ohm-2w resistors in that circuit, like Rz123 and Rz124 and check Fd102 3.5a pico fuse for open. That's actually a really easy set to work on for convergence problems because the entire convergence amp board is easily removed.
Bill
Dec 10, 2007 | Samsung HCM4216W 42" Rear Projection...
Double Vision
Unfortunately, the complete convergence amp board is no longer available from Samsung. But the board is available from ptscorp.com. Go to the website, get the telephone number, ask them what convergence Amp board you need and if they have it. If you know how to solder and unsolder, you can simply change the convergence amp IC's, on the main convergence board. The IC number if the IC's is STK392-040 Good Luck.
Jun 16, 2007 | Samsung HCN473W 47" Rear Projection...
Open Questions:
Televison & Video Logo
212 people viewed this question
Henry  Thomas
Henry Thomas
