Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Brand new Dryer starts then stops after 15 seconds
Dryer stops after just 15 seconds of running and the lights begin to flash that are below the start/pause button . The dryer is heating, but will not continue running until you have pushed cancel and then start again about three different times. There is also a clicking sound coming from the backside of the dryer that does not sound right. I don't think the dryer should be making this sound. Please help!!!
  • 979 Answers
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
Posted on Feb 11, 2009
  • everclavel
    everclavel Jan 29, 2013
    If this isn't a new dryer but I have the same exact problem, what do you think could be causing it?
  • Bill Dickerson
    Bill Dickerson Jan 29, 2013
    I believe the t'stat is bad just from the sound of it. It has a high limit control on it that keeps it from overheating. That is the design of a high limit control. If it doesn't function properly, then the result is either shutting off prematurely or worse not shutting off if it gets too hot. This is a blessing in
    disguise. If not the hi limit, then something is wrong with the computer board. Thankfully, you are under warranty. As far as the clicking sound, it could be the drum is not set right or the belt that drives it could be too tight or loose. Without hearing the sound, that would be my guess. Call where you bought it from and put it on them. This should be covered.
    Good luck, Bill
I called myself programming the new keys for my pt cruiser, but,it didnt take. At first it would start and run for a few seconds, now it wont turn over.what did I do wrong and how can I fix this?
Takes the master key to get it started again. The security gives you 3 tries to get the vehicle started, after the third time, it kills the starter.
2002 Chrysler PT Cruiser Note: You must have two valid keys to add a new key to the system.
1. Insert the first valid key into the ignition switch. Turn the ignition switch to the
ON/RUN position for at least three seconds, but no longer than 15 seconds.
Then, Turn the ignition switch to the LOCK position and remove the first key.
2. Insert the second valid key into the ignition switch. Turn the ignition switch to
the ON/RUN position within 15 seconds. After 10 seconds, a chime will sound.
In addition, the Vehicle Security Light will begin to flash. Turn the ignition switch
to the LOCK position and remove the second key.
3. Insert the new key into the ignition switch. Turn the ignition switch to the
ON/RUN position.within 60 seconds. After 10 seconds, a single chime will
sound. In addition, the Vehicle Security Light will stop flashing. To indicate that
programming is complete, the Vehicle Security Light will turn on again for
seconds and then turn off.
The new key is now programmed. The Remote Keyless Entry transmitter will
also be programmed during this procedure.
Repeat this procedure to program up to eight keys.
Oct 09, 2016 | Cars & Trucks
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
Nov 25, 2013 | GE DSXH47EGWW Electric Dryer
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
Brand new condenser vhc 680f starts cycle and then stops after ten seconds and lights flash. checked filter
Hi my dryer was the same. Apparently condenser dyers wont work under 5c, with all this mega cold weather my utility room was freezing brr and the dryer stoped after 10-15 sec and started flashing checked everything but still wouldn;t work. Found a swedish website (after spending DAYS looking for an answer) that said it mght be to cold so I brought the dryer into my house and wa hey its working again. Hope this helps xxx
Oct 18, 2009 | Mattel UB FUNKEYS Dream State Dyer and...
1999 olds aurora when you turn the key just says clean key wait 3 minutes
the key has magnet on it that may be weakening. It will have to be reprogrammed.
  1. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
  2. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
  3. Insert a new Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new key has been programmed.
Jul 07, 2009 | 1999 Oldsmobile Aurora
Hi, my machine starts for a few seconds then stops and pause button wont stop flashing, have tried turning off and on but same thig keeps happenig, please help x
if it is a HE kind of machine it is supposed to stop and start a bunch of times at the beginning of the cleaning cycle. Did you wait for a while to see if it ends up running the cleaning cycle?
the new machines are kind of freaky the way they work.
later
Apr 09, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Re set service light on a 2005 V 50
1. Press in and hold the odometer reset button.
2. Turn on the ignition to the run positon - not all the way to the start positon.
3. After about 15 seconds the orange "I" light (that warns the service needed message is present) begins to flash.
4. While it is flashing release the odometer button - if you do not do it in time the light stops flashing and will not reset.
5. Then turn off the ignition.
Oct 06, 2008 | 2005 Volvo V50
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
451 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
