Question about GE Advantium SCA1000H Convection / Microwave Oven
GE Advantium SCA1000 will not come on
No lights no power, I have replaced the 20amp fuse still nothing
    Brigadier General:
  • 8,619 Answers
Hi!
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If that doesn't help then there might be a burned wire or a component that can only be found out by opening it up, which is not recommended.
Please rate the solution if you found it helpful.
Thanks
Rylee
Posted on Feb 08, 2009
I have an Advantium 240 mounted over the range. There's a little trap door that covers an interior light while cooking. My door gets stuck and I hear a motor run. How can this be repaired?
That's the damper. It has to be closed when microwaving, and open when convection cooking.
See my video and also see the description text here GE Advantium microwave oven clicking noisy SCA1000 SCA2000 for more information.
Please note the phone number in the video is incorrect. See the Web site for more.
Nov 24, 2016 | Microwave Ovens
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Only microwave not working
Chances are you have a bad secondary / cook relay on the control circuit board. The relay can be replaced. See details here.
Jul 06, 2013 | GE Advantium 120 Convection/Microwave Oven
The turntable of my Advantium microwave model SCA1000 has stopped turning. It will sometimes move very sluggish but when the plate is on will not turn at all. Can you tell me what needs to be done to fix...
The Turn Table motor needs to be replaced in the oven, this will require dis-assembly to get at the part, and please remember there is dangerous high voltage present if you are going to do the work yourself.
Jan 23, 2011 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium - No power at all - PSB2201NSS01
Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Panel Locked
Press and hold CLEAR/OFF for about 3 seconds to lock and unlock. Download manual on link below: http://www.abtelectronics.com/images/products/PDF_Files/SCA1000-SCA1001_om.pdf
Jul 27, 2007 | GE Advantium 120 Convection/Microwave Oven
Manual
If the actual model number is SCA1000 then you can find the manual online here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=SCA1000DBB If that URL doesn't work, here is the compact version: http://tinyurl.com/yarzau If your model number is different, you can enter it here: http://www.geappliances.com/service_and_support/literature/
Oct 27, 2006 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA1000H Convection / Microwave Oven Logo
170 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
