Back to:
Tags:
Gateway Motherboard
Processor upgrade for Tabor 2 Gateway part #...
By 2Pansy - usenet poster
After doing some research and upgradeing to a P3 450
I found an interesting issue about the motherboard.
A 450 processor uses 2 volts.The processor uses VID pins to automaticially
program motherboard to the required motherboard voltage.
A 700 processor (Intel OEM 700) uses 1.7 volts.
I dropped in the 700 and it seems to be extremely stable.
Intel says the board supports a 450.Gateway tech said the 700 should pose
no problem.
MB 4M4PBOX1bios up to P21
Gateway will not sell me a new board..
Any issues I should look for.All hardware running great.
Thanks...Harry
So if I understand correctly the processor will tell the motherboard that it
needs 1.7 volts and not 2 volts through the VID pins
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Jimmy NY
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
All the processor does is request a voltage - it does not
check to see that it is that voltage being delivered. If the board
can't deliver 1.7V, the CPU is running at 2.0.
| The part I seem to read as these papers are notes is Gateway Part
| #850298240000321 on the GW motherboard reference sitesystem
seeems
| extremely stable but don`t want to lose a processor but do not want to
waste
| it.Thanks...Peace...Harry...still if I understand the VID process
correctly
| as I read it it should be no problemWhat do you think?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Processor upgrade for Tabor 2 Gateway part # 4000321:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Melissa
Rating: 0%, 0 votes
#850298240000321 on the GW motherboard reference sitesystem seeems
extremely stable but don`t want to lose a processor but do not want to waste
it.Thanks...Peace...Harry...still if I understand the VID process correctly
Thank You!
Solution #3
Not Rated (0)
Putty
Rating: 0%, 0 votes
what's the part number for your board?
When i upgraded my bios to P21, the BIOS could support CPU speeds upto
800Mhz (if i recall correctly).. But alot of people say the board can only
support upto a PIII450 due to voltage issues.
...Pritesh
Thank You!
Solution #4
Not Rated (0)
Cornish
Rating: 0%, 0 votes
Have you measured that the board is delivering 1.7V to the core?
The issue with these boards is that although the processor may
request 1.7V, the board's voltage regulator can't deliver it - you may
be driving 2.0V though the core (in which case the processor will probably
run just fine - until it burns out from overvoltage).
automaticially
| no problem.
| Thanks...Harry
it
Thank You!
Can you Help with these Motherboards problems?
Motherboards
It is a Asrock Mobo model # P4vm890 Thanks for your help
Motherboards
I have had this in for service and I have been told that...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
