Question about Canon PIXMA MP960 Printer
MP960 Cannot scan
The printer is connected to a Mac Airport base station, and the network and printer drivers are up to date. The printer will print across the network without any problems. However, when I try to use the scan function, it will not work. Using the MP Navigator scan software, it just says that its unable to communicate with the printer, and if I use the physical scan function on the printer itself, it won't go past the point where it says to press the scan button to start scanning. I would have thought this was a hardware problem but for the fact that the printer will print and copy without any problems. Can anyone suggest any solutions?
3 Suggested Answers
SOURCE: Scan function won't work with Mac OS10.5.5 & Airport
I have a new macbook pro OS 10.5 and installed a new HP L7590 all in one printer. Same problem. Called Apple and they confirmed that they do not have a driver for the Airport Express to allow scanning wireless. Therefore, SOL. If want to scan, then have to unplug from APE and plug into laptop. My solution is to use a USB hub and mount close to desktop so I can easily remove my HP and connect to laptop to scan often (or buy a cheap flatbed). GARY
Posted on Jan 16, 2009
Geekman
  • 32281 Answers
SOURCE: Every driver and every MP
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on May 05, 2011
Wireless router configuration
If you don't already have a wireless network, you can use an AirPort base station to create one. To configure an AirPort base station, you connect the Ethernet connection to the WAN port on the base station. In turn, the base station creates a Wi-Fi (wireless) connection to the Internet. Consult the documentation for your AirPort base station for more information on how to set up your wireless connection. Once you have a Wi-Fi network available, use these steps to tell your Mac to join it:
  1. Click the Wi-Fi menu icon airport_symbol.png and select your Wi-Fi network from the list of available networks.
  2. If prompted, enter the password for your Wi-Fi network.
  3. Check "Remember this network" to have your Mac automatically join your home network.
Mar 03, 2014 | ASUS Us Rtn53 Dual Band Wireless Router...
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
I am trying to connect a mac to the router - need some help
. you will need the "airport " networking gear
2. If you have a base station you need to connect this to your router or modem with an Ethernet cord ( RJ45)
3. Connect the base to the MAC pc Ethernet port.
4.connect the base station power and look for the power light to go on.
5.Open MAC applications folder then the "utilities " sub folder.
6. Double click the "airport utility icon"
7. Base station on the left of the screen ( click) then choose "continue".
8. if not on the left of the screen then select "setup a new station" then click "continue .
9. enter password for the base station ( write it down) keep it . click "continue".
10. next select create and new wireless network
11. create a name for the connection
12. then select "WPA" for the security then type in a password
13Next .make a selection for either a router or modem the click "continue.
14. next select DHCP the click continue
15.Verified then click "continue" then wait for the restart of the base station.
16. You should see "congratulations" then click "quit"
Aug 13, 2010 | Dell TrueMobile 2300 Wireless Broadband...
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Won't scan through network
You need to make sure that does it print or not. If it is printer then you need to disconnected printer HP 6310 printer and uninstall hp software using printer installation disk after that reboot your computer and reinstall completed printer software.
Thnx
Sachidanand
Aug 16, 2009 | HP Officejet 6310 All-In-One InkJet...
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Printer says printing but does not print
This post regarding the CLP-300/AirPort problem appeared on the Mac forums in June:
"This is not a known issue. The reason for you to face this particular issue is that these are both 2 GDI printers. Both these printers are designed to be DIRECTLY connected to a PC or MAC. They are not designed to be connected to any type of Printer Server, Airport Extreme Base Station or Powered/Unpowered USB Hub.
If the printers are to be used over a N/W environment then you may need either CLP-300N or any other N/W capable printing device. The other option would have been to use any device that is PCL or Post Script capable. These are not host based would have been better to suited this type of environment. Even though the previously mentioned methods of connections are still not recommended they would have been better suit as they are not host reliant drivers.
As to getting a refund it would highly unlikely as it is not a fault with the printer or drivers only as mentioned they are both designed with the intention of being DIRECTLY connected."
I hope this answers your questions. If you have any further questions please do not hesitate to contact me.
Kind regards,
IT Technical Support
Customer Contact Centre
Samsung Electronics Australia
T 1300 362 603 | F T 61 2 9746 6691
Quad Samsung, 8 Parkview Drive, Homebush Bay NSW 2127
Web : www.samsung.com.au
Jul 06, 2008 | Samsung CLP 300 Laser Printer
Wireless and multi function printers
I'm sorry to say that the answer to your question is no.  You can print wirelessly with most printers using either an Airport Extreme Base station or an Airport Express, but for scanning, you will need to be physically connected to the scanner.
If you wanted to, you might be able to set up that old desktop to be permanently (and physically) connected to the scanner, and then you could either connect to that PC over your home network to access the scanned files, or you could potentially email them to yourself from the PC.  That might be your best bet.
Hope this helps!
Oct 06, 2007 | Apple MacBook Pro Laptop Computer with...
Canon PIXMA MP960 Printer Logo
42 people viewed this question
old marine
old marine
