Question about Monte Carlo (5LCR52MW) Fan
Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
My granddaughter pulled the chain on our 3 speed Monte Carlo ceiling fan too hard which broke the 3 speed switch. I replaced the switch which was slightly different than the original. Now the fan has only two speeds, low and high. Two positions of the switch set the low speed, one position sets it to high speed. I've tried switching the wires to correct the problem to no avail. I'm thinking I may have damaged the speed control capacitor when I hooked up the new switch incorrectly. Would it be a good idea to try replacing the speed control capacitor?
  • 1,800 Answers
No no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Posted on Feb 08, 2009
  • Sherif Behna
    Sherif Behna Feb 25, 2018
    Thanks. I rewired switch again (this time with my daughter helping) with the same connection, but this time it worked. I believe I just had loose connection on one of the wires, as the clamp on the switch is not very firm.
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
The chain came out when i went to turn it off. now i can't start it.
turn power off to fan, and replace the pull chain switch. you can buy a switch at any hardware store. but take old one to get the right one for your fan. sometimes wal-mart may have one. good-day ! maybe the chain just broke. if this is the case, then just replace the chain if need be.MAKE SURE POWER TO FAN IS OFF WHILE CHANGING SWITCH !
Jul 11, 2011 | Monte Carlo Fans Indoor Ceiling Fans
The pull chain on my Regency ceiling fan has 4 positions, but the speed doesn't change: it runs on high speed for each of the first 3 positions, and then turns off at position 4.
mcdevito75 here Chances are the switch to change the fan speed is faulty, contact Ellington or see any store that sells ceiling fans for replacement switch if you can get one.
Jul 23, 2010 | Ellington REG52ABZ5LKRC Regent Ceiling Fan
Our fan is going in the reverse direction...how do we switch it?
mcdevito75 here, Generally, The Fan switch itself is a pull chain type switch on the fan motor itself, this is a fan speed switch, NOW! also generally the reverse fan swtich is another shorter pull chain switch just about an inch away from the Fan Speed switch or the longer pull chain switch on the fan motor. This reverse switch can also be a toggle type or slide type switch but will be close to the fan speed switch on the fan motor itself.
Jul 18, 2010 | Monte Carlo Dryers
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
Monte Carlo (5LCR52MW) Fan Logo
2,455 people viewed this question
Top Monte Carlo Dryers Experts
Craig Butler
Craig Butler
Tom Chichester
David Ellis Rhea
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
