Question about Sony Cyber-shot DSC-H2 Digital Camera
I can't move the flash off of the "off" mode.
The instructions say to keep pushing the flash sign until you get the desired flash mode. Nothing happens when I follow those instructions.
    Scholar:
  • 170 Answers
Are you shooting in the Auto mode? Change this to P or A and try to change the flash mode through the flash sign (top button on the four-way controller.
Posted on Feb 09, 2009
How do I program a Noma N1506 timer?
All Woods timers and manuals
ttp://waterheatertimer.org/Woods-timers-and-manuals.html
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
How do i turn back the hands one hour
The analog clock hands on the Casio 2747 will only turn in a clockwise direction, but there is a way to speed them up when you have to move them far around the watch face.
1. In Timekeeping mode (i.e. Date is shown in the digital display), push button "C" (bottom-left) 6 times to enter Hand-Setting mode.
2. Hold down button "A" (top-left) until the digital time starts to flash.
3. Press button "D" (bottom-right) to advance the analog time by 20 seconds, and hold down button "D" for High-Speed.
4. Alternately, for High-Speed, press button "D" (bottom-right) and button "B" (top-right) together at the same time, and then let go. The hands will continue to move automatically. Press any button to stop them BEFORE they arrive at the desired time, then press button "D" several times to arrive at the time of your choosing.
5. Press button "A" (top-left) to exit.
6. Press button "C" (bottom-left) if you want to return to Timekeeping mode.
Oct 28, 2009 | Casio DBW30SG7AV Databank Analog Watch
CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
Feb 28, 2009 | Oakley GMT OAK0531 Wrist Watch
Need instructions for a Timex Timer Moder #TE111 (TX12694TA)
To set the timehold down the TIM button until Day flashes, Use +/- to adjust then hold down time until hour flashes..Repeat until set.
To program,
1. hold down prog until the cursor starts to flash at 12:00
2. Press PROG to advance to the day or day group you want to program.
3. press + to advance the cursor to the desired ON time
4. press mode until display reads "on"
5. use the + to move the cursor to the desired ON duration? Clock shows this also.
6. press mode until "off" is displayed. then advance the cursor thru the period the outlet should be off. (stupid to have to do this!)
7. press MODE to select as the ON or OFF period(!)
8. press TIME to exit programming.
9. Press PROG again to program another set of days.
Stupid system.
Good luck.
Dave
Nov 23, 2008 | Hardware & Accessories
Keeps flashing 12:00
Hi jippers - try this :
1. Setting the Clock
When the coffeemaker is plugged in, 12:00 willappear until you set the time.
Entering “Time Set” Mode:
To set the time, hold down either the “Hours” or“Minutes” button until the clock begins flashing (about 2 seconds). You are now in the “Time Set” mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or
pressed and released lightly to advance one
digit at a time.
When scrolling, the numbers will advance
slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting,release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired.
Exiting “Time Set” Mode:
The “Time Set” mode can be exited in
one of two ways:
1. Press any button besides the “Hours” or
“Minutes” button. This will exit the “Time Set”
and activate the selected function.
2. Do nothing. If neither the “Hours” nor
“Minutes” button is pressed for a period
of five seconds, the “Time Set” mode will
be exited.
If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a nice day.
Jeff
May 08, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Setting time & alarm on Sharp Chronograph wristwatch.
Instructions for Sharp Alarm Chrono (Digital)
Push "Mode" button until the mode is shown that you want to reset, do this even if the mode you want to reset is all ready showing.
Push "Reset", continue pushes until the desired Parameter (Minute, Hour, or Second) is flashing.
Use "Start" button to advance the digits to the desired setting.
Push "Mode" Button to finish.
Jan 12, 2008 | Watches
Operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
May 20, 2007 | Timex T311T Clock Radio
Sony Cyber-shot DSC-H2 Digital Camera Logo
75 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
