Question about Sony MDX-CA580 MiniDisc Player
I have lost power to my sony cd player in my car
I have checked all the fuses for the radio. The one behind radio and fuse on the floor. All the wires are connected. I dont know what i should do. I was driving one day and it all worked fine, then suddenly lost power.
  • 323 Answers
Take the cd player out and run the 12+V to + on 12+V battery.
Run the Ground/Black wire to negative on battery. See if the cd player will turn on. If it does, check your ground in the dash. This is just a good trouble-shooting method to make sure the cd player system board is not fried.
Posted on Feb 09, 2009
Cd player has no power in my 2002 escalade
Check the radio fuse in the fuse box, if its good then its likely the in-line fuse on the power wire on the radio is bad. The second fuse is located behind the radio on the power wire.
Sep 12, 2012 | Audio Players & Recorders
I tried to install my cd player and the ground hit another wire i think and now i have know power to the radio and i checked the fuse and did not blow
check the fuse on your auto, to see if that is ok, the one that powers your audio system, and also check the fuse/fuses for the radio unit itself.Alternatively, the unit has died
Oct 21, 2009 | Sony CDX-GT300 CD Player
Sony CDX-s2000 in 2001 KIA Sephia
did you replace the fuse behind the wireharness if so did you check the fuses in the fuse block on your radio. if so you have checked everything try under the hood of your car there should be another fuse box check in there. if all fuses are good check the ground wire on the radio
Sep 08, 2009 | Sony CDX-S2000 CD Player
I have power going to the unit yet there is no display,a sony cdx-gt220,i know i have power because it is loading and ejecting cds yet no display.please help,its doing my nut in!!!!
I have a Sony CDX GT 530U. I had a problem with no display and I thought no power period. I did not try to install a CD, so maybe I did have power to the CD motor but no display. This was frustrating because I could get the old factory Nissan radio to power up and work so I thought I had a dead Sony unit. After a lot of monkeying around, I discovered I had blown a fuse while installing the unit (you should disconnect the negative terminal of the battery when installing the radio... which I thought I skip, that was a no no.). I had checked the auto fuses, those cheap little plastic fuses behind a panel below the stearing column inside most cars, at least all the fuses I thought went to the car stereo. Turns out I missed one that was labeled "Batt" or something like that, which was the constant power wire to the car stereo. There was another fuse for the Accessory power to the car stereo (the main juice went the key is tuned to ACC or Start position). Turns out the Sony unit display runs off the constant power, or at least the unit on/off button runs off the constant power wire, so even though the ACC power wire was live, the Constant power wire had a blown fuse and the unit would not turn on. Check all your fuses inside the car, I bet that's your problem. Constant power on my Nissan Sentra was a 7.5A fuse, while the ACC power ran off a 15A fuse, but your vehicle may vary. Good luck.
Jul 16, 2009 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Raido has no power,fuse is good .is there another fuse behind the radio. I replace the battery then lost power to radio ,I know the code
it could be a fuse, & yes there might be a fuse behind the radio depending wat type of radio, but every radio i've seen has one in the back...but i myself wud check the wiring behind the radio cuz if its not getting no power then i think tht the power wire cud be hooked up wrong...check tht & get back to me.
Jul 15, 2009 | 2001 Acura 3.2CL
Cd player lost power after hooking up new amp and sub
What AMPlifier are you using? Where is the main power wire and ground wire for the amp connected? (an amplifier with 25Wx2 or larger should be connected with proper fused wire directly to battery). I would check the fuses in your car as well (when the ignition key turned ON you should have power both to the Yellow wire and Red wires on the Alpine radio, there will be two fuses you must check in the car if not but I have no idea what car you are driving (one will be the radio fuse) (the second could be marked radio 2, or clock, or lighter ... or a host of other things) so I cannot tell you which ones to check, so look in your vehicle owners manual it should help. What did you connect the Blue / Whte wire from the Alpine radio to?
Apr 29, 2009 | Alpine CDA-9885 CD Player
My aftermarket radio will not turn on
I assume you didn't install the radio yourself then? Some installers put a inline fuse in. This would be located behind the radio. Some radios even have a fuse built into themselves, also on back side of radio. If those two solutions don't help ya, check the other fuses. Maybe the wiring for the radio was hooked into a different system other then the radio.
Sep 14, 2008 | 1997 Nissan Pathfinder
Pioneer deh 1600 has no power
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Memory loss since changing fuse!!!
The unit will have 2 fuses, or at least a second power supply that is generally connected to continuous power, best bet is straight from the +ve batt terminal. If this power supply has been disconnected or has a blown fuse, then you will also loose memory functions from you radio.
  1. Check first under the bonnet for a memory backup fuse holder that has generally less than 1 amp fuse,
  2. no luck, then about the rear of your fuse box for a fuse holder,
  3. or worst, behind the unit up under the dash. The wire from the back of the stereo on Sonys is generally the RED one for memory backup
restoring this power supply to your stereo will then allow for all your presets to be retained in memory
Good luck, happy to talk to you more about the problem, a "FixYa" rating will help my profile
regards
Graeme
Feb 14, 2008 | Sony CDX-GT300 CD Player
Car Stereo will not turn on
Most headunits (cd players) have fuses of their own. If those are are not blown, connect a simple test light to ground and with the ignition on, test your constant (yellow wire) and accessory (red wire) for power. If all fuses are good and you still have no power you can connect your red and yellow wires (whichever shows no power on the test light) directly to your vehicles fuse panel.
Jan 08, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Sony MDX-CA580 MiniDisc Player Logo
126 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
