Back to:
Tags:
Gateway Motherboard
Select 750 and 120GB HD
By Mini Me - usenet poster
I have a select 750 (AMD Athlon 750MHz, Jabil Kadoka
motherboard). It came with a 20GB HD, Win98.
I wanted to use a 120GB HD with pre-installed XP on it.
But after choosing the OS on bootup, nothing happens..
I updated the BIOS so it can see larger HDs now but to
no avail..
Has anyone run into this before.
Any tips would help.
regards.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Cato
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi!
Here is your problem...you need to go to the Gateway website, download
and install the available Bios Update. I too have the Jabil
Motherboard, but the serial number is slightly larger than yours:
4000646. My motherboard will only support a harddrive of 65.5 gigs.
Getting the bios update will enable the motherboard to recognize
harddrives larger than that size.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on select 750 and 120GB HD:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Chandler
Rating: 0%, 0 votes
The drive size isn't the problem. You will need to reformat and
reinstall XP once you've moved the drive into the system.
An XP install from one system won't work on another with different hardware.
Thank You!
Can you Help with these Motherboards problems?
Motherboards
It is a Asrock Mobo model # P4vm890 Thanks for your help
Motherboards
I have had this in for service and I have been told that...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
