Question about Epson Perfection V200 Flatbed Scanner
Need Replacement AC Adapter for Epson V200 Scanner
Can someone please tell me where I can find a replacement AC Adapter for my Epson V200 Scanner?
I have an Epson AC Adapter 220volt/13,5 Volt. Model A391VD As my scanner broke down. Fell from my table.
Posted on Aug 05, 2009
    Problem Solver:
Clas Olsen shop which is a Swedish shop in the UK sells an adapter with many heads and one pack sells adapters which Epson Scanners use. Try them. The adapter costs £25. Only shop i know that exists is in Manchester.
Posted on May 03, 2009
  • 43 Answers
Hey,
you can fint this cable at most electronic stores such as maplin.
you can also try searching in argos
Posted on Feb 08, 2009
I bought an Epson scanner from America with a power supply for 100v-120v can I still use this in Australia which has 240v. Regards ****
hi,
see the power rating on the power pack adapter. Unless otherwise stated,
most come with an international standard of 220v. I bet you can find an adapter with the right capacity that fits your scanner if that doesn't work.
Hope this helps
pls rate or vote this
Jul 05, 2011 | Epson Perfection V200 Flatbed Scanner
I have 2 Epson V500 Scanners, 1 of them I just have on standby. The one I use daily does not turn on. I tried using the cables of the standby unit already. I checked the fuses on the plugs of both...
  1. Check that the power socket switch is on Make sure your scanner's power cord is securely connected to the scanner and a working electrical outlet.
  2. If your scanner is supplied with a power adapter, make sure your scanner's AC adapter is securely connected to the scanner and a working electrical outlet.
  3. Make sure that the power outlet works. (If necessary, test it by plugging in another electrical device and turning it on.)
  4. Check that the power switch is on at the mains socket. If this is on, carefully check the power cable to ensure it is not damaged and remove then reseat it before attempting to turn the scanner on again. If your scanner has a power button, make sure that the button is depressed so it is turned on. Also, make sure that your outlet works and is not controlled by a wall switch or timer.
  5. Power off the scanner at the mains socket. Unplug the power cable from the socket, then remove and reseat the power cable from the scanner's power cable port. Plug the scanner back in at the mains and ensure the socket is switched on.
  6. If your scanner has a power button, does the power button depress when pressed? Press down firmly on the power button, if it is stiff and does not depress then there may be a problem with the button.
  7. Connect the scanner directly to the mains - not via a surge protector or extension lead. If your unit is connected via a surge protector or a power strip/extension lead, connect the unit directly to the mains socket.
  8. Try another suitable power cable. Check that other electronic devices connected to same power socket have power and try another mains socket and another power cable if necessary. Failing this try another suitable and known-working power cable. Depending on your scanner, a standard "kettle lead" or "figure of eight" power cable is used. If there is power to the scanner (indicated by an illuminated Start light), when a different power cable is used, then the fault is with the original power cable.
If the unit does not power on after following the checks above, contact Epson for support. If your scanner uses an AC adapter, then this may need to be replaced. If your scanner is over 12 months old, you can purchase a replacement AC adapter directly from Epson.
Nov 13, 2010 | Epson Perfection V500 Flatbed Scanner
What specification is it for me to purchase
Your part should be Epson AC adapter A241B 15.2v 1.4A 30W. The power cord is a generic type cord common with printers and scanners, it should be easy to find if the power adapter doesn't come with one already. You may be able to find it cheaper somewhere online like Ebay.
Mar 05, 2010 | Epson PERFECTION 1670 AC Adapter 2084614...
Need an Epson A221B 24v AC adapter
The part number is 2115845 if you put Epson 2115845 in your search engine you will get lots of hits for that power supply. Here is a link for an Epson parts distributor. http://www.encompassparts.com/products/?2115845
Hope that helps.
Aug 25, 2009 | Epson Perfection V200 Flatbed Scanner
How do I scan a slide photo / negitive on my epson perfection V200 scanner?
safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%20V200-_E
please go the above link and download the pdf file and you will get a complete pocedure on scanning a photo/negative
Aug 08, 2009 | Epson Perfection V200 Flatbed Scanner
Epson Perfection v200 stopped working on my imac
Try to scan using epson scan to isolate the issue. You can launch epson scan from applications. If you can scan using epson scan, call adobe to troubleshoot further on photoshop.
If you get an error epson scan cannot be started or if it won't launch. It could be connection or driver issue.
To uninstall/re-install twain on mac, follow the instructions:
- go to applications. Trash epson scan and epson scanner monitor
- Go to library then application support. Trash epson scanner module.
- Go to library then image capture. Trash twain data sources.
- Go to the hard drive. Click on user. Click on the name of your computer. Click on library. Click on preferences. Click on epson. Trash epson scan.
- Empty the trash.
- Restart your mac.
- Log on to support.epson.com. Type in v200 in the search box on the top right corner of the page then click search. click on the first search result. Click on the drop down box and select macintosh operating system instead of windows. click on the second driver down, epson12527.dmg then click on download now. Select no thanks, i prefer not to receive this information then click accept. Install the epson scan installer after the download.
- Then try to scan using epson scan.
If epson scan won't launch or you get an error, try a different usb cable.
Goodluck.
sherlyn c.
P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; }
May 21, 2009 | Epson Perfection V200 Flatbed Scanner
No final scan with Epson V200 scanner.
possible driver issue.
Please trash and re-install the drivers.
Apr 28, 2009 | Epson Office Equipment & Supplies
Epson Perfection V200 Flatbed Scanner Logo
1,376 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
