Question about Audax HM210C0 Car Speaker
DW50M audax recherch
Good morning,
I am looking for DW50M AUDAX tweeters. Can you sell me?
Best regards
Mr Coll
France
  • 74 Answers
You will find what you are looking for at www.geocities.com/pd071/audax.pdf
Posted on Feb 17, 2009
Have 2 jbl 615 get good base and sub but neither tweeter playing
You will need to determine if it's the amplifiers or the tweeter themselves that are not working. If you open up the cabinets and check each tweeter with an ohm meter for continuity it will show if the tweeters are working, in which case the amp is the problem. if the meter shows that the tweeters are blown, you should still hook up another tweeter or speaker to the horn amp to see if it's blown and therefor took out the tweeters.
If any of this sounds complicated, you'd be best off taking the cabinets to the repair shop.
Mar 16, 2015 | JBL Audio Players & Recorders
Where is the drain pump on a Electrolux front load washer
Good Morning Friend,
I understand that you want to know where the drain pump is located on your Electrolux washer, model# AWF 1435. In researching the model number you provided, I show that this was manufactured in France. I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you where the drain pump is located in your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Electrolux AWF 1435 Front Load Washer
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
No sound from top speaker
Yes Eltax will sell you a replacement part. THey also sell the woofer/driver as well. Changing either is simple. You will need a Torx screwdriver to unattatch the driver from the box. Then just pull it out, and attatch the connectors to the new tweeter. Make sure you get the wiring right for polarity. Ie look at the writing on the back of the tweeter and keep the wires going to the same connections on the new one. Screw it back in...and you are done. I have a pair of these as well, and have just done the same replacing both woofers that had been pushed in my my niece and her inquisitive hands !
May 17, 2009 | Eltax Liberty 5+ Main / Stereo Speaker
Missing recharging cord
Hello Krisso,
Your best bet is likely going to be contacting Motorola directly. Their parts department may have the charger available. Their product support number is 1-800-353-2729.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 09, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Have Sony KP-41S4U Projection TV. Am in France and a friend will look at it if I can find wiring diagram (lost). Fault is a 'flashing picture'. Started doing it when background was 'pale/white' but...
Hello Folks,
Thanks for getting back to me. Sorry, but my solution was to sell the TV. Am moving on to a canal boat and am getting rid of all sorts of stuff. Was going to repair TV before selling. I've given the buyer your Website details so you will be hearing from him.
Best regards,
Joe Killman
PS By the way, am living in France. Does that make any difference?
May 08, 2008 | Televison & Video
SP-UXV30 speakers
Offhand, the tweeter can be rated similarly to that of the woofer but not lower than 26 watts. I think your concern should also include the physical mounting and size since most branded units would be using proprietary components/parts and are not readily available.
Most electronics parts store would be carrying "generic" tweeters and "as per sample" would be your best basis. If I understand it right, **** Smith in Australia would be similar to Raon Stores in the Philippines or Akihabara in Japan.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | JVC FS-V30 CD Shelf System
Tweeters????
Hi oddone
You may have a problem with either blown tweeters, or a faulty cross over, or both. If you have a multimeter, you can remove the tweeter, and check it DC resistance. They normally have their impedance marked on the back of the magnet. If not, you can assume they should measure 8 ohms. If they measure open circuit (high resistance), then they have failed.
A good speaker repair guy can often fix an open circuit tweeter as they often break where the very fine wires attach from the voice coil to the terminal. you can take a turn of the voice coil and reterminate to solve this problem. If the voice coils are burnt, they will need to be replaced.
If the tweeter meters ok, then you may have a problem with the crossover capacitors going dry. Generally they are 2.2uf to 6.8uf in value, the smallest cap in the crossover. If the plastic coating on them is split, or they look a different colour to the rest of the caps, replace them, if they sound "hollow" replace em, if you are not sure, replace em. other than that there is not alot more to look for with a speaker box tweeter Good luck and happy listening.
If you have any dramas, get back to me here and we can talk more about it.
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
My tweeter in my atlantic 500 isnt working.
If you did not hear any sound from the tweeter, but you did on the new one, the old one is bad my friend. I tried to find an original replacement for you but I could not find it. I did however speak to someone on your behalf about your problem. I was informed that if you call them at 1-877-732-5374 and give them the dimensions, they can get you a nice not too pricey replacement that should sound good to you. I was told they go for about 70 to 100 bucks. Good Luck
Jun 05, 2007 | Wharfedale Atlantic 500 Main / Stereo...
Audax HM210C0 Car Speaker Logo
130 people viewed this question
Top Audax Car Audio & Video Experts
xxxxxx xxx
Are you an Audax Car Audio and Video Expert? Answer questions, earn points and help others
