Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Magenta band on lower half of screen
I have a magenta band about 6" above the bottom and it spreads across about half of the lower screen
  • 87 Answers
You have a bad optical assembly part #A-1606-008-A.
Posted on Feb 09, 2009
Panasonic TX-P42521B has a red/blue band across the screen (about2" wide) which is flickering and about 2" below is a broken red line. Any ideas? Thanks.
These symptom seems to be caused by a
defective D or SC board but in reality, they are
caused by a defective SD board.
To confirm this, disconnect the SD board from
the SC board (Follow proper SU/SD board
If the SD is defective, the screen will have a good picture at the top half of the screen and a completely black area in the lower half of the screen.
R
Jul 21, 2014 | Panasonic Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Hi, I have a 6 month old laptop Acer emachines E625 and turned it on this morning to find 3 thin black horizontal lines have appeared (with about 2 or 3 smaller lines above each of the 3 lines) at the...
Attach an external monitor to your PC. If the problem continues there, it's your graphics card.
If the problem disappears, you have stuck/dead pixels.
You could try a very gentle rubbing of the pixel(s).
Feb 03, 2010 | Computers & Internet
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
