Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki KE100 over revving
I have a 92 KE100 that will start but it will run at top speed ,not idle correctly. The idle adjuster doesnt have any effect up or down .
The throtle cable isnt stuck. I swapped the carb and it does the same thing. It had been running fine. What is causing the problem?
Clean your carburator, incl. bowl and most important the jet located in the rigth side of bowl. Good luck
Posted on Feb 25, 2009
I have zzr600, just got the carbs cleaned and just refitted it all, the bike struggle to start but eventually got going. Only problem it is now revving to 10000 rev as soon as i start the bike with the...
after getting the carbs done..did you get them resynicurised..could have a float not adjusted correctlly or a adjustment screw not dialed in correctlly,all 4 carbs need to be adjusted insynic..if not will make for a hard start or run too lean or rich
Apr 22, 2012 | 1992 kawasaki ZZR 600
How far does the high and low screw need to be unscrewed or screwed in on the carburetor. of the chair saw
The position of the screws is set while the motor is running, The screw nearest the cylinder is the low speed adjustment and the other is the high speed adjustment. Start the engine and adjust the slow screw till the motor idles smoothly without wanting to cut out. Then open the throttle and adjust the other screw till the engine runs at a good, steady speed without over revving. If the setting of the screws has been totally upset, start with the screws about 2 turns out from the stop and work from there until it starts and runs, then you can set the optimal running settings.
Mar 26, 2011 | Garden
2001 Kawasaki ZX-12R will not idle
Hi, Snowboard117 and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2001 ZX12r wont idle
Plz help just got 2000 zx 12r and im little confused
Kawasaki 2000 Ninja ZX 6R Service Manual Page 2
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
May 28, 2017 | 2001 kawasaki ZX-12R
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Hi there i have a ''92/93 model zzr400 kawasaki and it starts fine but needs throttle or it dies on me then i have to restart it i have to keep revs up to stop this , also after awhileriding it the temp...
Increase your idle speed at the fuel/air intake manifold. There should be a screw to allow for this adjustment. If that fails the engine timing may be off and should vbe reset to stabilize idle speed.
Mar 17, 2010 | 1992 kawasaki ZZR 400
In my honda xlr 125 i changed the main jet to #92 and slow jet to #35 is this ok? If so how can i tune the carb. I am from Sri Lanka. Its a tropical country.
The only way to know if the jetting is correct is to see how well it runs - and check the spark plug color.
You can start by warming up the engine and adjusting the idle mixture. Do this by turning the idle mixture adjustment screw (there are only two adjustment screws on the carburetor: one is the idle speed adjustment, the other is the idle mixture adjustment). Turn the idle mixture adjustment screw in or out until the fastest idle speed is attained. Then adjust the idle speed with the idle speed adjustment screw.
Now ride at full power and see how well it performs. If the engine cuts out or surges at full throttle, that means the main jet is too small. If the engine produces black smoke from the exhaust and doesn't seem to produce enough power, then the main jet is probably too big. Confirm the main jet correctness by looking at the color of the spark plug: white or light tan = too lean (main jet too small). Dark brown or black = too rich. Dark tan to brown color = perfect.
Nov 29, 2009 | 2000 Honda XLR 125 R
I have a kawasaki 300 byou 1990 moled 4X4 that i put a carberator kit in but just doesn't run right spits and sputters when i give it gas it will idle ok sometimes. drained all gas and cleaned out good....
It sounds like it is running too rich (too much fuel). First, make sure the air filter is clean and that there are no intake leaks between the carburetor and the engine. Also, try a new spark plug (they can go bad without warning). Then, with the engine at normal operating temperature and idling, adjust the idle mixture screw to attain the highest idle speed. After this, set the idle to the correct speed using the idle speed adjustment screw.
Test ride. If it still spits and sputters at half to full throttle, then you will need to get a smaller main jet - or go to a less restrictive air filter, such as one by K&N.
Finally, I am not sure what prompted you to put a carburetor kit in, but if the bike had been sitting for any lenght of time (more than 6 months) make sure the carb isn't plugged up.
Nov 20, 2009 | 2003 kawasaki KLR 250
kawasaki Full Suspension Mountain Bike Men Logo
484 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
