Question about Dell E173FP 17" LCD Monitor
Dell 17" monitor has turned 45 degrees
Even when I shut down the computer it returns the same way.  My wife was typing and all of sudden it went sideways on her.  Thanks!
  • 170 Answers
Http://internetducttape.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Posted on Feb 08, 2009
My lcd computer freezes very sudden
Press and hold down the power button until the computer shuts off. Run the computer in "safe mode" - by pressing F8 during boot the safe mode selection can be found. If the computer does not freeze then you may have a virus or the hard drive is corrupted.
Feb 09, 2013 | Dell E173FP 17" LCD Monitor
Computer Image turned 45 degrees
This is easy to solve, press ctrl+ alt and then the up arrow
Aug 31, 2009 | Dell E173FP 17" LCD Monitor
I have a Dell 17" flat screen ultrasharp monitor. It suddenly went dark and will not power up. Can it be repaired?
With the dropping price of monitors today; can get a good 22 inch lcd for less than $200 in most stores, it would probably cost more to have the old monitor repaired than just replace with a new monitor. Hope this helps.
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
How to shut off monitor power saver
If you open the Menu on the Monitor, there should be a tab with the name along the lines of " Management "
You'll be able to find the Power Saver option in there, and you should be able to turn it off through that.
I hope that helped, and please don't forget to rate my answer :)
Jul 05, 2009 | Dell E173FP 17" LCD Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
http://cgi.ebay.com/Dell-E171FPb-LCD-17-Flat-Panel-Color-Monitor_W0QQitemZ290290215133QQcmdZViewItem
You can buy a new 19 for about the same price
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254009
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Dec 30, 2006 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E173FP 17" LCD Monitor Logo
225 people viewed this question
Alun Cox
