Question about Tower CZ800 Heater
Need to replace tip over protection switch
Where can I purchase a tip over protection switch for a comfort zone tower heater cz800rc. The switch is under the base and is bad. Is there a part number or should I try to match it with one similar.It is UR 16a 125vac NOVA.
  • 1,902 Answers
I have looked everywhere for this switch on 7 different models and there is not one place that sells this piece. Sorry about that
Posted on Feb 09, 2009
The pull cord on my Comfort Zone CZQTV5M ceiling space heater snapped behind the metal protective grid. How do you get the protective grid off to re-tie the pull cord?
There is one 'release clip' on the outside of each side of the 'mounting bracket'.
Push the two clips inwards & it should release the body of the heater from it's mountings.
After that, I'd expect that you'd be able to unscrew a couple of screws to release the end cap & slide-out the grille which the pullcord passes through.
Best of luck.
Mar 10, 2018 | Comfort Zone Heating & Cooling
We have not used our heater in 6 months. It hasn't been moved. However, now it seems as there is no power going to the unit.
Check the outlet with something that works. Look for a tip-over switch that may need to be reset.
Nov 28, 2013 | Comfort Zone Heating & Cooling
Won't heat
might be a thermal protection device in line that failed, return to repair under warranty.
Jul 08, 2012 | Comfort Zone Heating & Cooling
In the Comfort Zone CZ7007 is there a repaceable fuse & if so is it located above the thermostat inside the control panel cover and where can I find another. No heat from unit or lights in switch but
I''m replying almost a year later, but this may help others who are having this problem. There seem to be a lot of problems with the tip over switch in the Comfort Zone radiator heaters (this is the switch at the very top, inside the panel, above the thermostat). I had the same problem- no heat, switches weren't lighting up. I bypassed the tip over switch (we have never tipped over one of our radiator heaters, so it's not an issue) and connected the switch wires with a wire nut and then further secured the wire nut with electrical tape. Now the heater works as it should again.
Nov 25, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
Where do I refill and with what type of oil. The Comfort Zone model# CZ 9009
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
Mar 30, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
On & off switch fell off or broke? How can I turn it on if the switch wont fit back in right?
If there are only two wires going to the switch you can unplug the heater and strip about 1/2 inch of insulation off of the wires and twist them together. Use a wire nut or electrical tape to protect connections.
If you can't find the right replacement switch you can use a simple toggle switch in it's place. Or just unplug it when you're done using it. I hope this helps you. Thanks.
Dec 08, 2010 | Comfort Zone CZ-530 Compact Heater
Will not work!
Give it a good shake. The tip switch may have tripped. Mine up at the hunting camp will tend to lock up without use. On the coldest night too.
May 13, 2010 | Comfort Zone CZ792 Electric Utility Heater
Tower CZ800 Heater Logo
201 people viewed this question
Top Tower Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Tower Heating and Cooling Expert? Answer questions, earn points and help others
