Question about Panasonic KX-TG1033S Cordless Phone
Accidentally locked handset KX-TCD510
As above; there is a large key in centre of base screen which prevents the handset from being accessed. There is no dial tone. The key pad does not respond. Am able to receive phone calls in. Am not able to retrieve messages. Please help.
  • 514 Answers
Try code 1000, that seems to be standard lock code pre-set for the phones, else take battery out for about 10 minutes or so ( this will likely erase your info, but you cannot get to it anyway). good luck!
Posted on Feb 22, 2009
Just purchased Panasonic model #KX-TGF380 phone system. How do I turn off built in answering message and record my own message
Make sure that none of the handsets are in use. First, record your own message. Press Menu then # 3 0 2 from the base unit or any handset. Menu is the middle soft key below the LCD screen on the base unit. It's the right soft key below the LCD screen on the handsets. The # key is below the 9. Use the Up/Down arrows to highlight Yes and then press Select. See the screen for the appropriate soft key. After the beep, speak your message while you are 20 cm (8 inches) from the microphone on the handset or base unit. Press Stop when finished. (The phone will stop recording if your message is 2 minutes long.) Press Exit on the base or Off on the handset to leave the menu system.
Turn on the answering machine. Press the button with cassette tape symbol on the base. Press Menu # 3 2 7 on the handset. Your greeting should be heard by incoming callers unless the unit is set to Greeting Only or the memory is full. To check this, press Menu # 3 0 5 . Again, use the up/down arrows to highlight your choice. Press the appropriate soft key to Save the setting.
If you do not want to use the numbers, you can use the Up/Down arrows and Select. Press Menu, highlight Answering Device. Then highlight Greeting. Then select Record Greeting for the first step.
These steps are available in the manual. All except for the greeting length are on page 57. The last section is on page 63. This is available from the product site: http://shop.panasonic.com/cordless-corded-telephones/corded-telephones/KX-TGF38.html#q=KX-TGF380&start=1 . Click on the Support tab. The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tgf380_en_om.pdf .
I hope this helps.
Jan 13, 2017 | Panasonic Lands Phones
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Kx-tg1100
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Nov 04, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
My base unit has just got locked and am not able to access any keys.
unplugging it for a few ours possibly over night should reset it while your at it go ahead and take the battery out of the phone and let it set to
Feb 06, 2008 | Panasonic KX-TH112 Phone
How to disable dial lock without password
I am using panasonic PANASONIC KX-TG2620BX and was locked by my daughter. We had it unlocked by:
press MENU
select Dial lock
Enter password 1234
Press save
Turn off Dial lock? press yes
Jan 08, 2008 | Panasonic 5.8GHz Cordless Telephone
Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Apr 01, 2007 | Panasonic KX-TCD580 Cordless Phone...
Panasonic KX-TG1033S Cordless Phone Logo
211 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
