See above
Most likely, the little rubber belt inside is slipping or has broken.
Your best bet is to replace the drive. You can purchase a good replacement for around $30 and up.
Until then, bend one leg of a paper clip straight and push it in the little hole on the front of the drive, usually located underneath the drive door and near the button. This hole was put there to allow you to open the drive in this kind of situation.
I use a safety pin, I suppose a paper cilp would work, thx
Sorry, I meant to say:
The problem doesn't show in your post, but I think you meant to say : "...doesn't open w/o using a paperclip." ? Is that correct?
The problem doesn't in your post, but I think you meant to say : "...doesn't open w/o using a paperclip." ? Is that correct?
