Question about Samsung SyncMaster 305T 30 in. LCD Television
Connecting xbox 360 with Samsung 305t monitor problem
I just can't get it to work with my XBOX, i have tried 2 different HDMI cables and I have PureAV HDMI to DVI adapter.
The freaking funy thing is, my old Syncmaster 730bf works Fine, just fine with any setting i can try from xbox.
All my 305t does, RED BLUE BLACK GREEN and some other colors start to flash I'm thinking it is some kind of error message, and yet the "manual" says nothing about it... Manual is a joke and I'm starting to think this new 305t is a total joke.
And somewhere i did read that 1080p native was available in the 305t (just plug and play).
I haven't even found any settings from my windows xp to change the monitor settings so it could "talk" to the monitor...Windows says "plug and play monitor".
3 Suggested Answers
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
  • 31 Answers
SOURCE: XBOX 360 will not display on my TV NOW!!! HELP!!
Sometimes cables will just go out, especially standard ones that come in the box on gaming consoles, DVD players, etc. My recomendation would be to narrow it down to either a problem with the XBOX, the TV, or the cable.
Step 1: Find a friend with another TV to try the cable and console on. If this works, we can automatically determine that the problem is with the TV, however it most likely isn't.
Step 2: If you know someone with an XBOX, take your console to their house and connect it to their TV with their functioning cable. If this works, we can rule out the gaming console.
If Step 1, 2 yield no results, then the problem most likely is with the cable. You can pick one of the up pretty cheap on Ebay, Buy.com, etc. However, I would recommend going with an HDMI if you get to this step. You will experience much higher quality picture, sound, etc, and have a much higher gaming experience than before.
Posted on Apr 13, 2009
How do I get sound from my Xbox to my monitor via a hdmi lead - DVD lead
As far as I know, the DVI cable can't send sound, so if you could use a only-HDMI cable or SCART cable, that should give you both picture and sound.
Nov 11, 2012 | Microsoft Xbox 360 Console
Yes , i have a proview 22 inch monitor and i connect it to my xbox 360 using an hdmi to dvi cable . the only problem is with the sound , it dont work what can i do ??i even try connecting speakers into the...
How do you connect the XBOX audio line out to the monitor audio input? If the xbox HDMI output is set to send the digital audio through the HDMI cable, you will not get the sound since you are using HDMI to DVI because the DVI is not made to accept the digital audio. You will need to to use the XBOX analog audio output instead feeding the audio cable with mini stereo phone plugs, please read XBOX user manual.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | Proview PL926WBi 19" LCD Monitor
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
HI,
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Thanks
proton
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Jun 18, 2009 | Televison & Video
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here. http://www.xbox.com/en-us/hardware/x/xbox360hdmiavcable/default.htm
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
Dec 29, 2008 | Microsoft Xbox 360 Console
360 won't let me use HD display settings
Have you set the actual monitor settings to 1080? sometimes you have to do that first. If it's not set first the Xbox will only recognize it's current settings.
Nov 07, 2008 | Microsoft Xbox 360 Console
XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Nov 25, 2007 | Microsoft Xbox 360 Console
Samsung SyncMaster 305T 30 in. LCD Television Logo
487 people viewed this question
Henry  Thomas
Henry Thomas
