Question about Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle
Crossman Sierra Pro Air rifle
The rifle worked 3 times. Now it will not lock when you **** it by breaking the barrel
  • barefootdive Apr 14, 2009
    I have exactly the same problem. Don't have the receipt and Walmart quit carrying the gun so can't exchange it. Must of had a bunch of problems with this gun since most stores don't carry it anymore. Called Crosman and they aren't much help and say they don't work on this gun. Guess they must of seen a lot of problems with it also.
    Took it to the local gun shop but they want $50 just to look at it plus whatever it costs to repair. Not worth it.
    So now I have a very diappointed little boy who got this for Christmas and only got to shoot it a couple times and now it doesn't work.
    Very disappointed with Crosman.
    If anyone knows how to fix this please email me at barefootdiver2000@yahoo.com.
    Thanks.
    Scholar:
  • 88 Answers
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Posted on Aug 29, 2009
Beemans sportsman rs2 trigger system not engaging after the break barrel been bend goes blank
Do you mean that you have never been able to cock the rifle ever
Like get the piston to lock up to the sear if so
Return to where you purchased it and get them to sort it
Mar 17, 2015 | Optics
Do you have to break in a fierce rifle barrel
You don't need to break in a barrel. Just use it normally.
NRA sponsors education for hunters and shooters.
Jan 02, 2015 | Optics
How do tighten / secure the barrel to the stock of my Beeman air rifle R9
It is a break barrel and if you secure it to the stock how will you cock it
Sep 07, 2014 | Beeman R9 Air Rifle, No Sights - 0.177...
How do you load and ****?
Hit the top of the barrel with your hand. Pull it down until it locks. Insert 1 pellet and close barrel.
Jan 04, 2011 | Crosman Phantom .177 Caliber Break Barrel...
How do you load crosman quest 1000. never owned a break barrel gun before
You load one pellet at a time when the barrel is broken open, the chamber is in the break of the barrel. One stroke, load, close, shoot, keeps you in shape. the old Sheridans, 10 pumps, really kept you in shape.
Aug 12, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
When i break the barrel it doesent catch.
Try to clean the barrel and make sure there is not an object jamming the spring.
May 27, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Reset to factory settings
Yes it is the same, it has the same barrel inside as a cross hair only you have a red dot. So just like you said, count the clicks and take it half way. You could do it with a vice, put a target up at 20 or 25 yards, depending on the pistol, lock it in a vice, shoot the gun a few times, and then put the cross hairs, dot, on the group, then you can fine tune from there. Check it out. And the bent barrel rifle, I had to stand on a barrel once to straighten it, actually I was jumping up and down on it, but I got it straight.
May 19, 2010 | Tasco 1x30mm Red Dot Scope With Matte...
Pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Feb 13, 2010 | Crosman Phantom .177 Caliber Break Barrel...
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle Logo
718 people viewed this question
Top Crosman Boating Experts
Ted Maxwell
Neil
Level 1 Expert
yobo007
yobo007
Are you a Crosman Boating Expert? Answer questions, earn points and help others
