Question about Kenmore Dishwashers
Water not draing after last cycle
Water not draining after last cycle, approx half inch left.
  • 6,784 Answers
This seems to be a simple blockage within the draining assembly. i would disassemble and take a look at the draining assembly for minor blockage.
Posted on Feb 08, 2009
Fridigaire FGHD2433KWI
While running a drain cycle. Listen for a hum. If its humming and not draing, it could be a few things. Your motor may not be pushing the water fast enough( bad motor ), Filter in the tub. Take spray arm off, twist lower collar with tab to the left and clean filter. or the drain line maybe clogged. Good Luck.
May 28, 2012 | Frigidaire Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Dishwasher won't drain. (Kenmore 3380957Rev A) It's been not draining that well for a couple of months, but then a couple of weeks ago, it just won't let the last inch of water out. --I can't see in...
The problem could be the pump, the drain hose or the timer. It will not drain if left to sit. The thing to try first is to put a cup of white vinegar in the machine and let it wash. This may remove sludge or scale blocking the strainer. 2nd take the hose loose at the sink drain and see if it is half clogged with grease or food. Check the hose and the nipple. Last, if it does not work take the bottom off the dishwasher. 4 screws and a plate. look for the pump and see if the hoses are clear. Sears will sell you a manual to repair and test this machine at its Parts Central on line
Jun 24, 2010 | Dishwashers
Not spining
1st,check if you have lay down the drain hose to the ground,2nd if the drain hose is blocked.3rd,if the drain pump has problem
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Got a new washer that has button to drain water but its not draing water or doing spin cycle and keeps coming up with error its an indesit wib101 washer it wont finish any cycle at all
check out the DRAIN MOTOR PUMP ,it could be clogged , take it out , inspect it , clean it , and try again , hope this helps AJ
May 13, 2008 | Washing Machines
Dishwashers Logo
107 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
