Back to:
Tags:
Gateway Motherboard
HP Photosmart 7760 Won't Print
By Janice - usenet poster
I have installed, unininstalled and reinstalled this
printer several times following the HP installation
proceedure and under the direction of HP and Gateway. I
have also downloaded the latest drivers from HP. I have
deleted all traces of the installation including all usb
drivers. The HP program says in installed successfully and
the "setup hardware device" has said it "product connected
successfully, only it does NOT PRINT!! It keeps selecting
LPT 1, I beleive it should be selecting a USB port. When I
pull down the printer port menu all the ports installed
with the program: DOT4, DOT4PRINT, DOT4USB & USB all say
(unknow local port). I did further research and found that
the USB port in installed as HPZID412.inf
(windows/system32/drivers/HPZID412.sys). HP nor Gateway
has been able to help me with this problem. Can any one
else??
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
maartenw
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi Tom, Thanks for trying to help. I made the mistake of
giving HP another try for the last few days. I do have a
start up disk, but am unsure as to what the command is
that starts the bios update. I have two .com(s) on the
floppy: gw2kboot.com & amiflash.com. Reading the "read-me
file, my guess would be amiflash.com. I am pasting the
file so you can read for yourself. I appreciate the time
you are giving me and hope we can get this printer to
PRINT.
Web-based Technical Support for Gateway products, live
chat with a Gateway Trusted Guide, file downloads, and
email support is available on the Web, at
#. Additional technical support can
be obtained via our Fax on Demand system at 1-800-846-4526
and our Automated Troubleshooting System at 1-800-846-2118.
BIOS for the Kadoka motherboard
0AASNP06
Windows 9x
7508997
11/21/2000
Table of Contents
Overview
Identification
Installation
Removal
Troubleshooting
Reason for Update
Applicable Part Numbers
Overview
This is a P06 BIOS for the Kadoka motherboard.
Identification
To identify if this is the correct BIOS update file for
your computer, follow these steps:
Computer turned off:
1. Turn on the computer and press the F1 key several
times. This will make the computer enter the BIOS Setup
Utility.
2. In the BIOS Setup Utility, the BIOS Version line
should read: 0AASNxxx (where xxx is the current version).
3. If the BIOS version begins with 0AASN, then this is
the correct BIOS update for your computer.
Computer in Windows:
1. On your screen, locate and click the Start button.
From the Start menu, click Shut Down. In the Shut Down
Windows dialog box, click Restart the computer, and then
click Yes.
2. After the screen goes black, press the F1 key several
Utility.
3. In the BIOS Setup Utility, the BIOS Version line
4. If the BIOS version begins with 0AASN, then this is
Installation
Before updating your system BIOS, read the following:
1. Preparing your computer
2. Copying the files
3. Performing the update
1. Preparing your computer.
Note: Before updating your computer's BIOS, it is
recommended that you enter the current BIOS Setup Utility
and write down the settings.
2. Copying the files.
a. After the Bios update file has been downloaded and
then double-clicked on, the files you need are extracted
to the folder C:\cabs\7508997.
b. On your screen, locate and double-click the My
Computer icon.
c. In the My Computer window, double-click on Local Disk
(C:).
d. In the Local Disk (C:) window, double-click the Cabs
folder. If you do not see this folder, click View the
entire contents of this drive.
e. Double click on folder labeled 7508997
f. In the C:\cabs window, click Edit, and then click
Select All.
g. In the C:\cabs window, click Edit and then click copy.
h. Close all windows.
i. Insert a blank floppy disk in the floppy disk drive.
j. On your screen, locate and double-click the My
Computer icon.
k. In the My Computer window, double-click on 3 1/2
Floppy (A:)
l. In the A:\ window, click Edit, and then click Paste.
m. The files needed to update the BIOS are copied to the
floppy disk.
3. Performing the update.
a. Restart the computer with the disk in the floppy disk
drive.
b. AMIFLASH utility will appear on the screen.
c. The message, Please wait (do not touch any keys at
this time), will flash on the screen.
d. After the AMIFLASH utility is finished, the system
will restart automatically.
e. Remove the floppy disk from the floppy disk drive.
f. The flash is complete.
Removal
Not available.
Troubleshooting
If the flash does not work, download it again and follow
all the Installation steps.
Reason for Update
BIOS will now display 65.5GB+ hard drives correctly.
4000594,4000629,4000635,4000646,4000673
in the floppy, start
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HP Photosmart 7760 Won't Print:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Mini Me
Rating: 0%, 0 votes
Do you have a Windows "Startup" disk? Try putting that in the floppy, start
the machine. when it has finished starting and you see some text on the
screen, the DOS prompt, and a flashing cursor, remove the start-up floppy.
Next, insert the floppy with the BIOS update. Now, type the command that
starts the BIOS update.
Plan B.
Open a DOS window. Insert a blank floppy. Type
format /s a: and press enter.
After the format is finished, copy the update files to the floppy.
Reboot the machine.
If all that is useless, let me know the www site for the update. I'll check
on it and let you know.
Let us know.
Tom
MSMVP PS-D
Thank You!
Solution #3
Not Rated (0)
Beresford
Rating: 0%, 0 votes
I have tried all of this, but thanks for taking the time
to try and help.
Printer Driver Using a
cc=us&lc=en&prodId=djpr&docName=bpd09106&cat=47701694
connect it first, then do
the printer. I find
that once the printer
hub and adding other
Thank You!
Solution #4
Not Rated (0)
Gary10
Rating: 0%, 0 votes
Thanks for taking the time to respond!! There is a BIOS
update at gateway and I tried to download without success.
I followed the directions exactly but when I try to
restart with the floppy in Drive A I get the msg "Non-
system disk or disk error". I also looked in the BIOS and
the "USB Legacy keyboard support" was disabled. I enabled
it, uninstalled & reinstalled the software again. Still no
luck. Maybe I need the upgrade but have no ideas on how to
make it work. If you have any suggestions I would be glad
to hear them. Thanks again.
the Gateway www site
Thank You!
Solution #5
Not Rated (0)
kcw573
Rating: 0%, 0 votes
These articles might also help:
USB Devices May Not Work in Windows 98 Second Edition
General USB Troubleshooting in Windows 98, Windows 98 Second Edition, and
Windows Me
I suppose that HP has already had you download their utility to totally
remove the printer and start from scratch. If not, please do this
HP Deskjet Printers - Removing and Reinstalling a USB Printer Driver Using a
Software Tool on Microsoft Windows 98 or Windows ME
Shortened URL: #
Make sure that you then do the installation exactly as instructed for your
printer. If the instructions say not to connect it until after installing
the drivers, then do this. If you are supposed to connect it first, then do
this.
Also, disconnect all other USB devices while installing the printer. I find
that having other devices connected sometimes seems to cause the device
installation to fail. I've found this most commonly with printers and
scanners.
Also, make sure that the printer is not connected to a hub but directly to
the computer when you do the installation. I've found that once the printer
is installed and working correctly, plugging it into a hub and adding other
devices does not seem to affect it.
PattyL
Thank You!
Solution #6
Not Rated (0)
Grant
Rating: 0%, 0 votes
By any chance is there a BIOS update file available on the Gateway www site
for your computer?
Tom
MSMVP PS-D
Thank You!
Can you Help with these Motherboards problems?
Motherboards
It is a Asrock Mobo model # P4vm890 Thanks for your help
Motherboards
I have had this in for service and I have been told that...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
