Question about Maytag Legacy Series Top Load Washer
Washer will not turn on
Need help fast as possible!!! when pulling knob to start wash----it does not turn on or even act like its getting electricity. Had a handy neighbor look at it who works on appliances for a living and he said it was the timer. I replaced the timer, but still no "juice", no sound, nothing....Please help asap
  • 82 Answers
Will it do any thing in any mode if not you may have a bad plug or wall outlet
Posted on Feb 08, 2009
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Apr 06, 2009 | Washing Machines
The wash tub in the washer drains as fast as it fills.
thats what it sounds like to me, chances are your drain hose iether runs along hte floor, or is taped in to the drain pipe securley, perhaps even directly piped into drain hose into dry well?? you definalty creating a siphon when the macine enters teh rinse cycle. you can purchase and "air-gap " from the plumbing supplier/ home improvement store. or just redo your existing drain line
Feb 19, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Maytag washer MOD # LAT 2300 AAE
If the machine does not start.
Make sure the circuit breakers or fuses are functional in the main electrical panel.
Try to turn them OFF and ON again.
You might need to check the thermal or non thermal fuses inside your washer.
If all appears in working order, you might have a burnt motor if no noise comes from it when you pull out the knob.
Apr 07, 2008 | Washing Machines
Maytag Washer Problem
Have you tried starting the wash cycle at several different time settings? Especially the shortest time setting, just before the start of the first spin? If it works at another setting, it's possible the dial/switch mechanism is worn and not making contact at your usual setting. In any case, a spray of a good electrical contact cleaner spray (NOT WD40 or similar) - with the power lead UNPLUGGED - sprayed into the switch mechanism might help. You would need to remove an access panel to get at the switch mechanism.
Ian from Australia
Dec 26, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not stop spinnig
You probably have a blocked pump. Pull it out and clear the obstructions- buttons, lint, etc
Jun 02, 2006 | GE WJSR2070B Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
