Question about Kenmore 16919 Built-in Dishwasher
Kenmore Ultra Wash II E6, E7, E8, E9
The cycle starts and fill. When the washer is filled it will wash but when it is time to drain it will just stop and one of the error codes will show up. I can cancel and drain it and start the cycle over again but the error happens on every cycle.
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Hi jabberr216,
I'm Harvey the Master Plumber.
Your question is: You have an older model Kenmore ultra wash dishwasher model #15805890. The control lock light is flashing. No buttons are working. The dishwasher does not turn on. Any solutions?
Sure! Someone must have activated the lock. It is next to either the 'air dry' or 'heated dry' button.
Press and hold that button till the lock light goes out. About 6 seconds. That's it. It turns on the same way.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
  • 338 Answers
SOURCE: Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Posted on Apr 10, 2009
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Wash cycle runs, drains, but will not fill up for rinse cycle
The water inlet valve solenoid needs to be replaced , they are made together.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Open Questions:
See all Kenmore 16919 Built-in Dishwasher Questions
Kenmore 16919 Built-in Dishwasher Logo
1,036 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
