Question about Tascam (cd-rw788) Burner
Burn cd on cd-rw 788 burner
I have a tascam 788 and the external burner. When i try to burn a song to cd it says song too short. Is my connection wrong? How do i solve this problem?
4 Suggested Answers
  • 624 Answers
SOURCE: CD Burner stops in middle of burning
Hi KayGo, People hate going over the basics but gotta ask: -Have you tried cleaning your read/write heads using a commercial cleaner? -Do you have any problems reading CDs? -What Brand of CDs are you using? If you're using the cheapies you should try a few quality brands such as HP or Fugi. -Have you checked the drives manufacturers specifications for blank disks? -What recording speed are you using? Try setting it lower and see if that has any effect. -How much reading and writing have you done with this drive? They do wear out and CD only R/W drives have a history of not lasting long. -Have you tried running a diagnostic on your drive? Here is a link to the Sony CD/DVD diagnostic tool. Meant for Sony drives but I have used this successfully on other drives - http://sony.storagesupport.com/cdrw/diagnostics.htm#dwn Let us know if you need any other assistance and don't forget to rate the posting.
Posted on Jan 03, 2007
  • 158 Answers
SOURCE: Iomega CD-RW 52x24x52 External Burner wont burn
have you checked the web site for drivers update and which burning software are you using if you are using on board xp stop using this and got for nero burning if you are on xp sp1 and try and upgrade to xp sp2 or win 2000 sp4 and clean cd lense and try that if same resaults it's time to redo windows as you may have currupted dll files and change usb leads over if possable
Posted on Aug 13, 2007
  • 1019 Answers
SOURCE: disc read problem (Tascam CD-RW 750)
Run a laser head-cleaning disk through it.
Theres probably a spec of dust on the Laser.
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 189 Answers
SOURCE: Tascam 788
Sorry to hear about your problem. A number of things could cause this error to appear including bad sectors on the hard drive (which will require a reformat).
Two things you can check though before getting into replacing or reformatting the drive (which will erase all of your data) are 1) Make sure the power adapter hasn't failed. A bad or incompatible adapter won't provide enough power to the drive when it tries to spin up and could cause this error. You can try a replacement after-market adapter but you'll have to match the specs in the manual. 2) You can open up the 788 and inspect the two wires connecting the disk drive to the motherboard. One is power and the other will be an IDE ribbon cable. If either is loose that could be the cause of your problem.
If you do determine that the drive is bad you'll need to remove the drive, hook it up to a PC and reformat it there. Then reinstall it in the 788 which will upon bootup automatically reformat it again with Tascam's proprietary disk format. You can optionally replace the drive. I believe Tascam's site has a list of drives which are compatible with the 788. Reformatting (or replacing) the drive will obviously cause all of your data to be lost, but should get your 788 working again (if a bad format was the problem).
One thing of note if the drive format being bad turns out to be the problem is that Firmware versions 1.07 and below have a bug which can cause bad sectors to corrupt the drive after delete operations. If you have a firmware version which is 1.07 or below you should upgrade to a newer revision or you'll risk corrupting the drive again in the future. You can get the upgrade and instructions on how to apply it here: http://www.tascam.com/products/788;9,16,132,19.html
Best of luck and hopefully it's just a loose connection or a bad power adapter.
bd.
Posted on Nov 12, 2008
Asus Varidrive
Had the same problem on Mac.
Solution: You need to connect device to machine on Linux and give it "eject" command.
Do not to connect device to Windows machine. I was trying to burn cd on Mac. Then it was interrupted in the middle of burning (some files were missing). When I connected drive to Win it tryed to unsuccessfully read it and eventually explorer.exe crushed. And it will not resolve until you reboot the machine.
Jul 28, 2013 | ASUS SDRW-08D2S-U/BLK/G 8X Slim External...
Need manual for cd-rw788 burner
Where can I get a manual for a tascam cd-rw 788 burner ?
Sep 21, 2012 | Tascam (cd-rw788) Burner
How to burn a CD to a Pacific Digital CD RW from a Tascam Porta Studio - is it possible?
If the tascam has a digital out and you have digital inputs in an upper model sound blaster, you should be able to load the files on the computer. There are converter software pieces that will convert anything out there. Just do a search. (Load your files first.) . Short of that, record the analog output from the Tascam into a GOOD audio card with little floor noise in lossless WMA or similar and convert from there. Burn to CD last.
Nov 25, 2009 | Pacific Digital (U30274) DVD±RW...
My pc says 'drive not ready' when i try to burn cd
does it read the cd ? make sure that the IDE / SATA port are connected properly / or even usb cable if you use external cd burner...
May 13, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Tascam 788
bd.
Nov 12, 2008 | Tascam (cd-rw788) Burner
Nero error PLEASE HELP!!!!
My expert Hanto solved this problem for me. It waas the cd's I was using. They were no good due to continuously trying to burn them on a cd burner that was dead.
Sep 06, 2008 | Lite On Lite-On 48x24x48 CD-RW IDE w/Nero...
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Nov 08, 2007 | Tascam CD-RW2000 Burner
Problem with my Iomega CD-RW External USB Burner
open and replace comunication cable.. HDD Cable,
Aug 13, 2007 | Iomega (32885) CD-RW Burner
Tascam (cd-rw788) Burner Logo
162 people viewed this question
Top Tascam Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Ben Armstrong
T-Comtech Repairs
T-Comtech Repairs
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
