Question about Philips DVP5990 DVD Player
No Picture on HDMI using Philips DVP5992.
First off. Just found your site and used the great region free code. Thank you. I got this player for a handful of DVDs. A lot of inputs are used up on my Onkyo 705 with HDDVD and Blue ray. I wanted to just move a hdmi cable from the Blue ray to the Philips DVP5992 whenever I wanted to watch a european DVD. When I plug in the HDMI cable I do get sound but no picture on the Sony Wega KV-34HS510. I even then try a composite cable at the same time but I get a jumping black and white picture. I then unplug the HDMI cable and the composite picture turns color and remains steady. (Of course no sound.) I then check on component on another tv input and that picture is ok but on plugging in hdmi again the sound comes back and component goes black. Also in the Philips DVD SETUP I can never select HDMI on the VIDEO setup page as it is shaded out. Maybe my DVI Sony TV is to blame. Any thoughts would be great,Thank you.
    Problem Solver:
  • 10 Answers
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Posted on May 11, 2010
How do I unlock the region to play all blu rays on my Philips bdp2930 blu ray player
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Region hack to blue-ray part is not possible with any blue-ray players. You can make it region free to its DVD part.
Dec 11, 2014 | Philips BDP2930/12 Blu-ray Player...
Tip
Philips DVD player Model: DVP5992 Fixing the orange screen
<span>How to fix the orange screen back to normal!</span><br /><br />The other day i turned on my Philips DVD player model number: DVP5992 and the screen was orange red, instead of blue/grayish! I have tried to google the problem, but no luck. So what i did is, i disconnected the power cord and the HDMI cable and waited for like 30 min. After 30 min i plugged it back in and my screen went back to normal, being blue and gray!<br />If you have this problem, do this, and your screen will turn back to normal.<br /><br />Also if you want multi-regional code to play all regions DVD's, do this:<br /><br /> press Setup <br />select the Preference Tab (4th setting to the right)<br />keep that tab open and Press 1,3,8,9,3,1 <br />Press up/down on remote key to select "0" <br />and hit "OK" then hit setup to exit. <br /><br />good luck and enjoy!<br />Naztech<br />
on Jan 03, 2011 | Philips DVP5992/37 DVD Player
How To set a Philips DVD player dvp5996k to "multi Region" ?
There's a lot of useful information on the videohelp.com website.
Philips DVP5996K region code
posted by satish_z2002.
  • Please turn off all power using remote
  • Turn On Power
  • Eject Tray - Player will display NO DISC
  • Enter Setup and navigate to preferences page
  • Type 138931 on your remote
  • Player will display Default Region Code
  • Use up down arrow keys and select 0(Zero) for All Regions
  • Hit Enter
It's now region free.
DVD Player and Blu ray Player region codes
Jan 19, 2014 | Philips GOGEAR Audio Players & Recorders
How do i change my region code back?
There are three options you can try: 1. download the DVD drive's firmware from the manufacturer and re-flash the drive's firmware, this will reset any region code in 99% of all DVD drives. http://www.ehow.com/how_2316521_flash-dv? 2. you can use software that, in realtime as you play the videos back, removes region code out of the file transfer stream from DVD to playback software. The best software to do this that I know of is called "AnyDVD". http://www.slysoft.com/en/anydvd.html 3. use region free DVD playback software like VLC, which is freeware. http://www.videolan.org/vlc/ The first option is the riskiest, if something fails while flashing the firmware, it could disable the drive, but it is 100% FREE. The second option involves buying software and making sure its running before watching any DVD's in the future. The third option is probably the safest, cheapest, and simplest for you. The DVD drive is not going to prevent playback of a region 1 or 2 movie if its set to region 4, its the playback software that makes this decision. If you rely on commercial DVD playback software or Windows Media Player, they will not allow the playback. VLC is region free, it doesn't even check the region the DVD was produced for.
Apr 10, 2010 | Philips DVP5992/37 DVD Player
How can I change my PHILIPS DVP5992/37's Region Code from ''1'' to ''9'' or ''0''?
HI!
I think you'll find this very useful!
To multi-region your machine:
press Setup
Press 1,3,8,9,3,1
Press up/down key to select "0"
and press menu to exit.
Good luck to you and enjoy!
Jul 25, 2009 | Philips DVP5992/37 DVD Player
Philips hts3357 dvd needed the code to use any region dvds only play region 2
Open the tray, press STOP 7344660- now will be region free
Oct 04, 2008 | Televison & Video
Philips DVD Player DVP3960 1080i HDMI DivX DVP3960/37 trying to find a code to unlock the multi region.
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player
Done.
Jul 18, 2008 | Televison & Video
I have a Philips DVD Player DVP3960 1080i HDMI DivX DVP3960/37 and I need a code to unlock in my system to play multi region.. Thank you
Press "Setup"
Done.
Convert DVD Player to all regions
I found solution: Go to Google and type - DVD help. There is a site with codes for DVD players. http://www.videohelp.com/dvdhacks/philips-dvp-3260/9309
Just type in the codes by: Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number.
Press "OK"
Jul 15, 2008 | Philips DVP3960
Unlocking code for Philips HTS 3500s DVD
Eject disc. While open press 99990. Thats it.
Jan 24, 2008 | Philips HTS3500S System
Philips DVP5990 DVD Player Logo
601 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
