Question about Car Audio & Video
I installed my Jensen VM9511TS, ipod interface and rear view camera - works great! I just bought the XM interface, the XM tuner and I'm having problems. The XM turns on, plays on the Preview station for about 2 minutes and cuts out! I spoke with Jensen (Audivox) and they told me it's teh XM Mini Tuner. I went out and bought another one at Circuit City and the same thing happens. Reloaded the drivers to the interface from XMdirect. . .no dice. Any suggestions?
  • 4 more comments
  • Louis Papaleo
    Louis Papaleo Feb 08, 2009
    As I said, the headunit works, actually plays the Preview station and then the audio cuts out. If the headunit powered down, it would be a fuse or similar problem. The head unit continues to work, the touch screen displays XM Preview, but no output. Clearly not a fuse issue.
  • Louis Papaleo
    The headunit remains powered. Three is no audio output. The touch screen displays XM and Preview. . . no sound!!
  • Louis Papaleo
    I can't get signed onto XM as they require 15 - 20 minutes of continuous use once they activate the tuner. They cannot activate the account!
    XM told me that if it works properly, the Preview channel should be continuously active.
    I lose audio after 1 or 2 minutes!
    Sirius/XM is the only service provider for these units.
  • Louis Papaleo
    Louis Papaleo Feb 09, 2009
    Dowloaded and installed the firmware 3 times!
    Nothing . . .
  • Louis Papaleo
    Audiovox/Jensen said contact XM. XM said contact Audiovox. The retail - an ebay electronics power seller (read that "you're out in the cold seller") said contact Audiovox. That's why I'm here. I checked all connections, the 8 pin plug has been plugged and replugged. Nothing. So far the only solution is to throw the whole thing away!
  • Louis Papaleo
    No I haven't. Certainly, I can try it. Why do you think it would work?
  • 19,396 Answers
It looks like there is an issue between this paricular audiovox model and your XM.
When this happens often there is no way out, as it is a factory defect.
If I was in your shoes I would insist in calling XM, see Help & Support.
XM distributes different models for different stereo manufacturer, ensure you have the right one.
Let us know how it goes and give us feedback on your problem.
Thanks.
Posted on Feb 10, 2009
    Genius:
  • 1,011 Answers
Sir,
Click this link (pdf) for some troubleshooting tips and also check all the connections and replace cables.
thanks good luck
Posted on Feb 09, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Have you tried leaving the units (both the XM and the Jensen) powered on even if there is no sound for about 30 mins?
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 09, 2009
    Appreciate considering to try the idea of 30 minutes. As in most satellite based systems, the receiver would need time to initialize itself, lock into the satellite signal depending on where the unit is in the footprint. Again being a receive only and to my understanding, all information would be embedded in the incoming signal, including the activation. To my knowledge here is no way for a receiver (receive only) to transmit back to the signal source that it is ready for activation, it has to wait for the next cycle of data and thereafter you will be prompted on what steps to take to finalize activation. Hence the 30 minutes wait. Presumably, that time would be more than sufficient for the XM receiver to have downloaded all the necessary information.
    Alternately, you can inquire from Sirius/XM any other method of account activation (though I doubt since activation is always paired with the receiver). Or you could try bringing the XM mini receiver back to where it was bought and ask them to activate/test it for you.
  • 6,784 Answers
Sounds like a bad model production run. i would call the manufacture for a list of bad model numbers and see if you may have bought one. the next time you go to the store that you bought it from, see if they have a mini tuner with a different model number. this may be defective.
  • 256 Answers
Hi, It sounds like xm hasn't activated your subscrition, please check that you have a current activation.
Posted on Feb 08, 2009
  • Jim London
    Jim London Feb 09, 2009
    hi, I almost forgot, the unit has an 8 pin connector from the tuner to the unit , pull it off and inspect the pins and make sure they are all OK and that the key is straight when you replug it. Good Luck!
    President:
  • 2,559 Answers
What Xm satellite service provider are you with?
It sounds like you only have the preview service and not a subscription.
  • Randy Hough
    Randy Hough Feb 09, 2009
    You have a preview account
    You said "they can't activate the account because you can't stay on long enough"
    This makes no sense,Anyone can activate an account even if they have no XM device.
  • 1,800 Answers
Check for Fuse or a shorting out inside ur Car wiring.
  • Jalal Sordo
    Jalal Sordo Feb 08, 2009
    check out if the firmware of the unit is corrupted or missing some features.
    then flash it or upgare it firmware through main download page of ur unit.
  • Jalal Sordo
    Jalal Sordo Feb 09, 2009
    this is strange.
    maybe some radio electronic part is warming up while trying to continue.
    check any thing warm up in the borad check:
    • Capacitors
    • ressistance diods.
    • any thing worm than usual.
    plz make me updated.
Ipod 4th gen not charging on Jensen VM9311TS
The issue is that the 4th Generation iPod takes far more energy to run than your 4gb iPod. Updating the firmware has nothing to do with it. It's the amount of energy/voltage that this new 8Gig unit takes to run.
Think of it as a 4 cylinder verses an 8 cylinder engine. The 8 takes far more gas to run.
Blessings,
A/V Media Guy
Nov 21, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
I am looking for reccomedations. I have a 2003 VW Passat. I would like to purchas a Touchscreen, DVD/GPS/CD player that will fit in the center console, neatly, any recommendations?
The Pioneer AVIC systems are fantastic. I have a Jensen VM9311TS which doesn't have GPS, but it has the other features, plus XM Radio and iPod interface, and it's a great unit that I love having. Much less money too (less than $400, vs the $1500-2500 for the AVIC).
Nov 18, 2009 | 2003 Volkswagen Passat
Ipod hook up
YES you can!! Touch the "video" button on Jensen, theyou MUST use your iPod to findthe video you want to play on the screen and SET YOUR iPOD SETTING TO "TV OUT"!! I have the same decand iPod and it's GREAT!! Just remember that on videos, set the iPod to TV OUT, and control the video from the iPod!!
Enjot man,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
J-link hook up
My Jensen TV/DVD unit came with a media box as well as the head unit. The media box was the interface where my iPod and XM antenna plug in, and everything is routed via a DIN cable from the media box to the head unit. I'd think you're missing that extra module that allows all the auxiliary hookups.
Jul 21, 2008 | Jensen VM9510 Car DVD Player
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Jul 17, 2008 | 2007 Honda Odyssey
Jensen VM9511TS... Problem
Try a hard reset. If you look on the face of the unit, you will see a little pinhole located on the lower right side, stick a paper clip in there and hold in until the system reboots itself, this should be done while on.
Feb 01, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen 9311
I don't think j-Link cable capable of video, at least not with the first generation Ipod Ready Units anyway. Check with your local stereo shop if there is a way to they should know. Please keep me update. Thank you.
Oct 13, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
No video, only sound from tv tuner.
You need to plug the male yellow wire into one of the female wires that says media control...... something along those lines..... youll figure it out
Oct 06, 2006 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
