Question about EdgeStar Portable Air Conditioner Heater
Heater doesn't work on my EdgeStar AP420HS Portable AC/Heater
When using this model as an air conditioner, it is a dream: it runs perfectly, and everything gets to a very crisp, cool temperature without any wetness. The exhaust hose vents to the outdoors nicely. In the winter (I live in New England), it would be absolutely catastrophic to keep a window open - even 4" - in order to vent the EdgeStar when using it as a heater. I cannot imagine that this is even a good idea! So, I've been trying to use the EdgeStar's heater, and it doesn't work. No error messages. It just keeps reading the same temperature that it was when I first turned it on, no matter what I set it to, and the air does not blow any warmer than when I first turn it on, even if I leave it on for hours. What is wrong with my heater? Do I actually and ridiculously need to vent a heater outside?! Help!!!
  • beatgoddess Feb 18, 2009
    RE: meBNme's question, it is not a gas heater; it is electric.
  • Danny Clark
    Danny Clark May 11, 2010
    Is it a gas heater?
4 Suggested Answers
SOURCE: edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Posted on May 06, 2008
  • 8 Answers
SOURCE: Heater keeps cutting off as if it reached the set temp.
sounds like its in defrost mode and the electric aux heat is not working
Posted on Mar 13, 2009
  • 11800 Answers
SOURCE: My Edgestar portable AC/Heater unit
The blink is an indication of overheating. Have you cleaned the filters? Have you made sure the exhaust tube doesn't have any kinks in it? Are you using a mains plug that has a grounding connector and doesn't overheats?
If all are how they are supposed to be then the compressor is failing - more precisely its starting capacitor: when heated it starts to short. The unit will have to be opened and the capacitor replaced - it's a special capacitor specifically made for that, you will need to get an exact replacement. Do not keep using the unit in this condition: the capacitor will eventually fail for good and it will fry the compressor in the process, killing the unit.
If you don't have the minimum experience required to do the job safely don't take any chases and call a pro.
Posted on Aug 03, 2011
How many BTU
This is rated at 1070 watts cooling. 1070 Watts cooling is 3650.9915473 BTU/Hr.
3650.9915473 BTU/Hr equals 0.30424929561 in Refrigeration tons....Pleazer Appliance...
Mar 08, 2015 | EdgeStar AP420HS Portable Air Conditioner
Do I need to keep the hose connected to the window in winter time while I use the heater.
The hose is only needed to pump out hot air while using the AC features and not needed at all for heater functions.
Oct 15, 2013 | EdgeStar Portable Air Conditioner Heater
Weatherking ac blower motor hesitates , slows down then blow out fuse
Check the the motor's run capacitor and check to ground and between motor windings with an ohmmeter.
Aug 25, 2013 | EdgeStar AP420HS Portable Air Conditioner
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Water leaking
You have to open it and clean out the water passages.
Jul 23, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar 12,000 portale air conditioner and heater
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
Heating
http://www.edgestar.com/ownmanuals.htm
Here is the URL for the Edgestar owner manuals. You can select your unit on the page. You'll need Adobe Reader to view the manual.
Nov 28, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar Portable Air Conditioner Heater Logo
333 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
