Question about Mitsubishi WS-55809 55" Rear Projection Television
MITSUBISHI HD 1080 series
I recently moved my mitshi hd 1080 series screen tv...it was working fine until the next day. I am unable to get a picture and the menu screen is distorted...looks like the screen is warped. Any ideas on what the problem is?
Please Help,
Elica
  • maddalena407 Apr 20, 2009
    We just got the same problem!  The power shuts off after about 1 second. Don't see any solutions yet...
    What happened and how do we fix it?
  • Mitsubishi Master
  • 8,617 Answers
Most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoMITSUBISHI HD 1080 series - a193b32.jpg82b89b8.jpg
Posted on Feb 09, 2009
Have mitsubishi 1080 series. When you turn it on it kicks back off in about a second. Was working just fine when I turned it off.
Posted on Apr 05, 2009
Well mis elica_terry sounds like you need to come see me!
Posted on Sep 30, 2010
After being on a little while the picture on my tv has a shadow. Like double vision of what's on the screen. The tv is a little old but is a Mitsubishi HD 1080 series. I think it's the original big sc
If this is areally old set and not a flat screen lcd or like that, It is suffering from magnetism problems and you need to deGaus it! THe tool needed is a round deGausing coil that is moved around the screen with the button on it held until finished.
Jan 01, 2013 | Televison & Video
The screen shield of my mitsubishi HD 1080 diamond projection tv is scratched and shows rainbow color dots in some places. What can I do? Can I fix it? Replace it?
The outer screen on most models is clear and called a protective screen and prevents glare---if it has that it has 2 more screens behind it.
Getting at the outer on is not so easy---the entire frame for the screens has to be removed, the inner screens removed to get at the outer screen to remove it (if 3 screens you can do without the outer one except if it got scratched before--next will be the next screen behind it.
Check with mitsubishi to see if the screen that is damaged is available or not.
Oct 29, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi hd 1080 series tv. When I power on the tv, there is no picture displayed on the screen. Any thoughts on how to resolve this issue? Thanks, Matt
Hi mbarrett3260,
Your bulb was gone to its peak burning life and now its dead, replace it and your unit will back to normal again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 05, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Mitsubishi HD 1080 55
Your unit has some sort of Thermal problem either with the PSU fault, or a thermal problem elsewhere that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. T
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Mitsubishi WS-55805 55" Rear Projection...
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
2,803 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
