Question about Toshiba Satellite A105-S1712 Notebook
Can't upgrade memory past 1gb when max is 2gb
Trying to upgrade satellite a105-s1712 memory but it won't accept the 1gb chips just turns on and off when try to boot but can put 2 512mb chips in and boots fine
Looked for an bios update cant find one for this model
pc is supposed to have a max of 2gb memory
  • mikenyc01 Feb 10, 2009
    I have the same problem. I have a satellite a105-s1712. I purchased 2 x 1g 533Mhz DDR2 sticks from 1st choice memory (their website provided the memory exactly for the model number of the laptop). When I replace the 512 with the single 1g or both, the laptop just appears to try to start a couple of times and then shuts down. I have also instaled the latest Bios (2.3) as instructed by Toshiba website. Still nothing. The 512 that works fine with the laptop has the following on it: 512MB DDRII 533FSB on one side, and 512MB 2Rx16 PC2-4200S-444-12-A3 on the other.
    Appriciate any help.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Look on the RAM stick and tell me the speed and type of RAM that you have..for instance 133MHz DDR or 266MHz SDRAM..etc..
I have the same issue with my laptop. I have not been able to get the laptop to accept 2gb of memory yet, but I did find something that works. If you put your 512mb memory that works in the laptop and then add a 1gb stick in the second slot it works. Or at least it did for me. It's better than nothing. I am still trying to figure out how to get it up to the 2gb max. Will add a solution if I figure it out.
Posted on Mar 25, 2009
Hey, I actually found out the problem after doing some reasearch. You probably saved money on your 2g cards. They are not fully compatible even though the vendors claim that they are. If you get your memory from the maker of your laptop you will not have an issue. Kingston is also a safe choice. All these OEM cards seem to have problems. There is tons of people with the same problem. I never bothered to re-order and go though the whole RMA process. I think 1.5 g is not all that much slower than 2g. But for the next laptop (dell) i order the upgrade kit from dell and had no issues.
Posted on Apr 10, 2009
Will a compaq Presario R3000 take one 2 G memory stick? I am trying to upgrade the memory on my partner's laptop. Can 1 stick of memory, 2GB, be used instead of 2 1 Gigs?
Hi Bronzen...
HP website for you laptop...
Please take time to rate me
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=384511&prodTypeId=321957&prodSeriesId=384511&objectID=c00208189
According to the HP website: 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB
Sep 15, 2011 | Compaq Presario R3000 Notebook
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Would a 2x 1gb ram upgrade be better for a toshiba a105-s2236 or would a 1x2gb ram upgrade be better
That computer supports dual channel memory. You would be better to install memory in matching pairs. (2x1GB) On the hardware page of my website www.rfcomputer.biz there is a link to Crucial memory. Just put in your make and model and they will make recomendations
Feb 02, 2010 | Toshiba Satellite A105 S2236 Notebook
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
What kind of memory can I put in my toshiba satellite a105-s1712
DDR II SDRAM.
You'd have to look at your manual to find out maximum memory.
Mark
Mar 28, 2009 | Toshiba Satellite A105-S1712 Notebook
Memory upgrade problem
I did some checking on your model laptop and it says that the maximum supported amount of ram is 2gb (2 x 1gb) and so since the slots are made for 1gb max each then thats all they will see even with bigger 2gb chips installed
Dec 04, 2008 | Toshiba Satellite A135 Notebook
I put two 2GB RAM in my memory slot and only one is registering, so instead of 4GB RAM, I have 2GB. Why is this and what can I do to get the full 4GB?
ok i checked on your model and it says 2gb RAM max and so it is probably seeing both chips but only seeing 1gb each since that is what the slot is made for..
But to be totally sure you might wqant to check the bios and see what it says since some bios will sometimes give more details as to how many chips are installed.
or take out one chip and turn the computer back on and see if it shows 1gb or 2gb if it shows 1gb with one 2gb chip then you will know that the slot wont read more than 1gb.
Dec 04, 2008 | Toshiba Satellite A100-S8111TD Notebook
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Compaq presario c714nr upgrade memory too 2gb laptop
http://h10032.www1.hp.com/ctg/Manual/c01301275.pdf
Page 43 of this manual seems to have the best documentation on memory for this machine. I saw a 2GB max in another document and this shows the biggest module as 1GB. I would believe that infers a pair.
Dec 18, 2007 | Compaq Presario 700 470024-192 Notebook
Toshiba Satellite A105-S1712 Notebook Logo
325 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
