Question about Harman Kardon AVR 100
How to play dts/dolby digital on HK AVR5
Any external decoder or any other options
    Scholar:
  • 93 Answers
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Posted on Feb 09, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Why can I not change the setting from pcm to dolby digital on my tv
You don't. You change the signal at the source device end, not the TV.
If you have connected a Blu-ray player or a games console, then set the device audio option to Bitstream. This will send a data stream to the TV that it will decode either as Dolby or DTS depending on the source signal format.
Dolby Digital is only an option for an external AV source connected via HDMI. That's the only way to get a Bitstream signal in to the TV. The TV's internal tuner is only capable of PCM audio. It's a DVB-T tuner (standard definition) rather than the DVB-T2 tuner needed for HD. Even then, only the HD channels are encoded in DD.
Iff your BD player or console is decoding to stereo PCM, then it's doing the same job as the TV. There's a small advantage with one of the audio processing modes in how it limits the dynamic range, but other than that PCM and DD will sound identical. This is especially the case with any TV that has no optical audio out, as in this case. The TV can't pass a DD signal out to an external audio system. So all sound is played via the internal speakers or headphone jack. It'll all sound the same, PCM or DD.
Oct 13, 2014 | Samsung Televison & Video
Auto format decode means?
HI,
There are so many audo formats like Dolby Digital Decoding, Dolby Digital EX Decoding, Dolby Pro Logic Decoding, Dolby Pro Logic II, Dolby Pro Logic IIX Decoding, dts 96/24 Decoding, dts Decoding, dts NEO:6 Decoding and dts ES Decoding Stereo etc. What ever the AVR get a digital input It will decode the format and convert the same While it in the Auto format mode. If auto format is not selected it will convert the same in to stereo.
Ajin
Feb 09, 2012 | Audio Players & Recorders
I've just bought a philips blu ray player (BDP3000) and connected to my Philips 42PF9631D Plasma using an HDMI cable but no sound comes through. Any ideas?
I would suggest few options for you to get the audio back. I hope video is coming out correctly?.
1. Select the proper HDMI input where you connected BDP.
2. Set the HDMI audio set up to ON/bitstream(do not select OFF).
3. If the Digital Audio Output set up is available select PCM/ALL and not OFF.
3. If you have connected external amplifier pls..remove this?
4. Are you playing a DVD/BD with normal Dolby content or DTS content? Because some TV sets do not have the decoders to decode the DTS content hence there would be no sound.
Let me know if you still have problems
Jan 10, 2010 | Philips 42PF9631D 42 in. Plasma Television
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Jan 24, 2009 | Onkyo TX-SR606 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
I have a panasonic SC-PT850 DVD home cinema system, and although it says it is DTS and Dolby 5.1 compatable but it does not give out any sound at all when i play Blueray films or Playstation 3 games which...
Not so much an answer more a shared problem with a slight insight. On the Panasonic manual page 40 http://www.panasonic.ae/EN/Manuals/SC-PT550%20-%20850W.pdf
It states the following: This unit can decode the surround signals received through cable TV box, digital broadcasting or satellite broadcasts. Refer to your equipment’s operating instructions for details. Only Dolby Digital and PCM can be played with this connection.
So it sounds like the SA-PT850 unit will decode DTS from an internal source ie DVD but not from an external source ie ps3 or WDTV which is a shame because I own a WDTV. The solution for me is to convert the dts to ac3 (Dolby digital) which works great. But not sure if this is an option for you.
May 08, 2008 | Panasonic Audio Players & Recorders
Playstation 3
First of all, Linear PCM is the best option to choose. PCM (Pulse Code Modulation) is a format for uncompressed raw audio data.
Some 5.1 sets have Dolby ProLogic II for example. The raw PCM output gets spread at your speakers dynamically. Meaning the decoder of your set interprets it the way it thinks is best. For example, if it gets a high frequency tone, it sends it to the center speakers as for human voice has a very high frequency. The center speaker is meant for dialogs.
But when you choose a compressed, encoded format such as Dolby or DTS the channel devidance is already mixed for you for optimal theatre experience.
When you choose DTS or Dolby in the menu of your Blu-ray Disc it will originally output a raw PCM audio stream. The decoder knows how to decode the DTS data out of it when you use the DTS audio track from the movie. The same goes for Dolby. Some movies can output pure PCM, but then most sets use ProLogic II to devide it over the speakers.
It's kinda hard to explain how it works, bottom line is.. there's nothing wrong.
I hope it makes sense to you and your question is answered.
Greetings,
DarkNeogen.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Harman Kardon AVR 100 Logo
225 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
