Question about JVC KS-FX250 Cassette Player
Tape player keeps switching sides
The tape deck to my head unit keeps switching sides nonstop when u put a tape in. i didnt try to clean it cuz i didnt have the cleaning kit thing and its not hooked up right now. wanted to see what it could be first.
also, the sound only works on one side. is there a fuse i can replace in the head unit or did it just decide to stop working completely. right now it is wired to one side so i have sound on all speakers.
any advice or anything you know would be very helpful with repairs.
Thanks
The adapter is tripping your radio's auto revere. The radio thinks it's at the end of the tape so it switches sides. Tape adapters especially the cheaper ones are made a couple 100,000 at a time an sometimes the machine that makes them is off so it makes bad adapters. If you look at the face of the adapter you will see a silver head in the center just to the left an the right of the center hole you'll see two smaller holes one on each side. look inside these holes an make sure there's nothing in them no padding or plastic tabs. If there is anything in these holes remove it. This is whats tripping the auto reverse .These hole should be about a 1/4" deep . next with a small razor blade shave all four sides about the same as the thickness of the blade this should remove any burrs or misshapen plastic.
Posted on Apr 10, 2010
My technics cassette deck tr575 everything seems to work all the functions all the buttons but when I put a cassette tape in the unit I see no responce on the db meter... Everything is functioning on
There are 2 long switches, maybe 4" long, called record/play switches. These can certainly cause this. Try cleaning them with the power unplugged. You would turn the cassette deck on end, so the switches are vertical. Use LPS-1 or LPS-2, and spray a very small amount in the end. Work the switch back and forth and see if that helps. Good luck.
Nov 25, 2014 | Technics RS-TR575 Single Dual Cassette...
The cassette deck in my '95 BMW 325i now just flips from side 1 to side 2, without actually playing. Everything else with the stereo still works fine. Might this be a problem that a non-profession
The unit has to come out of the car and taken to a auto Stereo repair shop. I would guess without seeing it that there is a loose belt that is causing a detection of the deck not turning the reel the detector is on and that tells the electronics the tape has stopped and if there is no drive in the other direction it does the same thing. If a capstan belt breaks there is no drive in either direction. The belt may not be hard to replace but you need to know the routing and the size then just order from MAT Electronics or MCM Electronics and put it in. I also think the Head and Pinch Rollers are going to need a real good cleaning. Use Naphtha for that. I serviced car stereos back in the 80 and 90 not so much anymore. If you can do it depends on your technical ability.
Jan 20, 2013 | Audio Players & Recorders
My Teac LP-R500 audio cassette player squeaks when playing. Tapes do not squeak on my other player.
It all depends on where the squeak is coming from. Some very clean rubber parts make kind of a squeak but I don't think that is your problem if you use cartridge cleaning systems. The real answer as a 40 year plus Tape Deck Technician is to get in there and see what is causing the squeak- it may need some oil in reel table, Pinch Roller or even the Capstan Bearing. Manufacturers do not like to put oil into
unit as it makes for no repairs and you will not have to buy a new one.
I worked at Teac but this unit is far after my exit- I still do repairs full time on the product though. I am sure I could resolve it- I am in the Chicago are.
Jan 01, 2013 | Teac R-H500 Dual Cassette Deck
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
Was given an Ampex AG-440 tape deck that stopped recording after sitting for about six months. Any ideas? (I lost the Manual) Everything else works fine. When put into record mode all lights are lit...
try cleaning the record head, Most people only clean the play back heads on tape players, the record head is just off to one side of the main playback heads , you can use a Qtip and rubbing alcohol to do the cleaning
May 21, 2011 | Audio Players & Recorders
Recording from VHS to DVDR was going fine,then I stopped getting a picture. DVD player is fine plays back recordings etc. However tape player starts to play shows picture then stops showing video and...
Possibly dirty video heads. I would suggest that you run a head-cleaning tape through the VCR deck to shift surface dirt off the heads. If that doesn't work, or it sort of works, but not satisfactorily, unplug unit, carefully remove top cover, and with the VCR deck in view, gently clean the heads with a soft cloth or special cleaning stick (these look like flat q-tips but are intended for VCRs - available from electronics/hobby stores) and some alcohol (methylated spirit will work if that's all you got - but isopropyl alcohol is recommended - available from the same places as the sticks) clean the guides (gently so as not to disturb their alignment) clean the pinch roller/capstan shaft - CTL (on the right-hand side of the drum) and FE (left side) heads as well. The whole tape path should be carefully cleaned. Refit top cover (carefully), plug unit back into power, wait until it completes its startup/loading procedure, then put a tape in. You should now have a playback picture with the sound. You only need to do this as required if head-cleaning cassettes don't work properly.
If none of the above cures your problem, then the heads are abraded/worn - let's hope that isn't the case here. This model does not use a built-in head cleaner.
Feb 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Tape Deck in Car
Sounds like a poor "connection" between the cassette head and the head in the adaptor.
This could be caused by either head being dirty, or the tape head may be mis-alligned.
You can clean the heads with a proprietary head cleaning fluid.
Check with a standard tape.
Also, if your head unit supports it, switch the auto-reverse control. Some adaptors have dual heads for auto-revers decks, and some only have a single head.
May 07, 2008 | RCA RS2640 CD Shelf System
Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
Sep 24, 2006 | Aiwa XR-C3RW Shelf System
JVC KS-FX250 Cassette Player Logo
1,799 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
