Question about Sharp CD-XP120 CD Shelf System
Sharp cd-ba2100 error 0306
Help me to solve can't open cd
SOURCE: Sharp CD-BA200 MIni Component Stero System
Follow up, I called Sharp USA @1-800-237-4277 and spoke to a gentleman there and he said that with this error message the unit had to goto a Sharp Repair Depot to be fixed, so since shipping charges plus what ever it costs to repair the unit will cost more than a new one mine on the curb.
Posted on Dec 16, 2007
zair
  • 82 Answers
SOURCE: protect error
The 'Protect' error means there is a DC voltage present in the output section(which should not be there). This can be caused by a defective output IC(the big IC on the heatsink). Disconnect the IC and see if the error goes away.Also check the resistors around the IC.
Posted on Mar 22, 2008
zair
  • 82 Answers
SOURCE: cd-ba200 error 0306
Check the CD belt. Part number 92LBE231616.
Posted on Mar 24, 2008
zair
  • 82 Answers
SOURCE: cd stuck err 0306 message
Since the cds are stuck inside, you need to open the unit and remove them. There are four screws on the top cover. Remove them (2 on each side) and lift the cover. You should see the cds, remove them, then plug on the unit.
Posted on Jun 19, 2008
SOURCE: error 0306
hi there, I suggest you should open the top cover of the cd tray, have a look inside do a little cleaning also when you screw back in, make sure you screw in properly( you propaply find that someone had open it up before and screw it back in really tight so the cd trey jam inside, or another alternative something might of broken inside and tha can stop the cd trey from opening. it happen to me before and thats how i fix it. good luck hope it works.. cheers
Posted on Jan 03, 2009
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Sharp CD-BA2100, when I turn it on it starts making a clicking sound and if set to tape one or tape two, it shows "error". When set to "cd" it comes up with error 0306 and the cd tray...
the rubber rope which conect the motor to a small gears to open the cd was cut due to long using ... this sound of clicking coz the small motor is running and its not attached to anything ... its a small rounded rubber rope ..the bad news is you have to break some plastic stuff to reach the motor in the repair depot they change the whole upper part so it costs alot ... but if you can reach it it will work perfect as its new.
Sep 08, 2011 | Sharp CD-BA200 CD Shelf System
I am getting an error Message 0306 or 0203 when trying to open the cd tray on my Sharp CD-BA150 Stereo System what can I do to fix this problem
For the error 0306, simply remove the lid of your system and clear the dust out/off of the lense and surrounding areas. (i.e. soft cloth, canned air, ect...) Hope this helps!
Jan 18, 2011 | Sharp CD-BA150 Shelf System
Protect mode
I own a Sharp DVD Micro System XL=DV60 that began to have a "protect" error message when I crank up the volume. Not sure if this applies to your system, but it could be worth a try. Before you proceed, the solution requires you to open up your system (Do not proceed if the unit is still under warranty :)).
IF you are not experienced in opening up electronic equipment, I suggest you find somebody who does. The error on my system was caused by the cooling fan being stuck or not able to spin. The system has a sensor or sense circuitry wherein, when it detects that the "amplifier" IC heats up, it spins up the fan to cool it down. IF the system detects that the fan is not spinning during the cooling phase, it will give out the "protect" message. Note that the fan only spins when you crank up the volume. Less or 0 volume will shut down the fan due to it's "energy star" feature. One possible reason why using headphones does not show the error, since headphones require less energy that the main speakers, thus the amplifier IC does not overheat. To solve the problem, I cleaned out the dust in the system via a 1 inch wide paint brush (haven't tried the compressed bottled air used to clean computers BUT it might do) and nudged the fan. Played the system w/o a cover and observed the fan operation and so far it has solved the issue. I plan to lubricate the fan shaft with very small amount(less than a drop) of machine oil using a syringe. If it does not work, I plan to see if I could purchase a replacement motor for the fan...
Again, I have not seen the internal layout of CD-BA2100 and not sure if there is a cooling fan. But then again, it's better than having the "protect" error popping up. :) hope this helps....
Oct 27, 2008 | Sharp CD-BA2100 CD Shelf System
Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Sep 17, 2008 | Sharp CD-BA2100 CD Shelf System
Cd stuck err 0306 message
Jun 09, 2008 | Sharp Multi-System Mini Component System...
Protect error
Nov 25, 2007 | Sharp CD-BA2100 CD Shelf System
Cd shelf will not open
There is a belt in the CD mechanism that may have to be replace. The part number of the belt is 92LBE231616.
Sep 16, 2007 | Sharp CD-BA200 CD Shelf System
Sharp cd -bp 1350w
I think that depending on if it is old usally before it dies it starts not wanting to open disc drive add coment if it is old or new...
Aug 20, 2007 | Sharp CD-BA200 CD Shelf System
Cd-ba200 error 0306
Jun 10, 2007 | Sharp CD-BA200 CD Shelf System
Sharp CD-XP120 CD Shelf System Logo
142 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
