Question about JVC TH-C6 System
Jvc th-c6 subwoofer won't turn on
The subwoofer won't turn on after I replaced the cord to the dvd player. I see no fuse or reset button on the outside
  • reyes_js Apr 09, 2009
    I recently purchased a TH-C6 system and after getting everything connected I still have no sound. I can hear the subwoofer click like it's turning on, but still can't get any sound. Am I doing something wrong?
Check the little prongs inside of the cord, they are very fragile and if they get pushed in wrong, bent and broken off - you would never see one on the floor. These should all be straight and be able to make contact. Hope this helps!
Posted on Mar 16, 2009
How can i replace the cord that goes from the speaker to the receiver
Run "JVC TH-C6" by eBay and check the 'include description' box. Or seek a DIN cable with the same number of pins elsewhere.
Sep 05, 2011 | JVC TH-C6 System
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
Jvc dvd TH-C6 says locked and dvd wont eject
While the system is off
Press and hold the stop button and disc one open tray button at same time
It will say unlocked and then power up and you are good to go
Hope this helps i just unlocked mine got info from jvc user manual on website this link is the pdf
http://resources.jvc.com/Resources/00/00/95/LVT1147-001C.pdf
Jan 15, 2009 | JVC TH-M505 System
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
Jvc th-c5 dvd theater system
Probably have a bad center unit to subwoofer cable. Sometimes the pins inside the cable bend or break. I paid 33.00 for a new one on the JVC website.
Dec 25, 2007 | JVC TH-C5 System
Subwoofer won't turn on
try and see if it as internal fuse ? if not the bad news is that possibly the amp as gone
Jan 01, 2007 | JVC TH-M303 System
JVC TH-C6 System Logo
575 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
