Question about Epson Stylus C62 InkJet Printer
One of the 3 colors will not print
I have two Stylus C62 printers. In one of them the yellow will not show up in the other the blue does not show up. Cleaning the nozzles does not help. What should I try next?
  • 353 Answers
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Posted on Feb 13, 2009
My printer is not printing
Go to the setting on the printer and go to maintence or option ink? set it to both color & black. If you are only using black set it to black only depending on what you have on the ink cartidge. I hope this was helpfull.
Jun 08, 2009 | Epson Stylus C62 InkJet Printer
No printing
you need to have an autochip for your printer or it might have reach the maximum capacity of printings or replace ink immediately
Feb 25, 2009 | Epson Stylus C62 InkJet Printer
Epson C62 printes only in blue
Since you haven't responded to our queries, I think we can say "Solved by Poster". If not, please respond with a new post to this effect.
Jan 13, 2009 | Epson Stylus C62 InkJet Printer
See banding on paper
I think we can say this poster has solved the problem him (or her) self!
Jan 09, 2009 | Epson Stylus C62 InkJet Printer
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Printing from Microstation to Epson Stylus C62 printer
Hi AW
More info is needed. Does the printer print normally from Windows programs? Is the "microstation" running under Windows, or if not, what operating system? If it's not a standard operating system that has C62 drivers (DOS, Windows, Linux, Mac), you will have to write your own driver I'm afraid. Let me know.
Gerry
Nov 13, 2008 | Epson Stylus C62 InkJet Printer
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Oct 18, 2008 | Epson Stylus C62 InkJet Printer
INK
download the utility ssc service from the site ssc.com and use the power cleaning option
Aug 14, 2008 | Epson Stylus Color 640 InkJet Printer
Stylus C62
You can go into the properties of the printer, and set it up to print everything in black only. This is the only way to FORCE the machine to use black ink for everything. The drawback to this, is that when you want to print something in color you will have to go back into your printer's properties and uncheck the black only option.
Jul 22, 2008 | Epson Stylus C62 InkJet Printer
Red "drop" shaped light blinking
On my C62 I it usually shows the "Status Monitor" when trying to print, which shows the levels for B/W & Colour.
If not go to CP/Printers, select the C62 (make sure ON) then Properties, then the Printing Prefs button (at bottom). The Main tab usually has this fill level indicator; also try the Maintenance Tab Status Monitor option. These are real awkward to find from scratch but useful when you get to know they're there.
Also if you remove and replace a cartridge you are usually given the option to say whether it is a new or old cartridge - choose new if you know it's nearly full. Don't take NO for an answer to their stupid questions!!!
Clwyd
Apr 15, 2008 | Epson Stylus C62 InkJet Printer
Epson Stylus C62 InkJet Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
